I put my vcd mpeg into nero and it said i had to re encode it so i did. Then I went to burn it and it says encoding error. Did I do something wrong? I followed the instructions on the site.
DONT USE NERO TO ENCODE... it sucks on encoding...
Use TMPEGnc instead. Look to the left under tools...
Then follow a HOW TO guide...
I did use tmpegnc to encode then I opened it in nero the it asked me to re encode it. Didn't I say that?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Nope, you did not..
Goto "LOAD" and load a template. (VCD,SVCD whatever u NEED)
After it encodes the MPEG, you should be able to burn with NERO. If it still tells you to let NERO encode it again, just uncheck the COMPLIANT (S)VCD box, and burn ayways. But first, check the DVD player list to ensure that you DVD player will even support VCD or SVCD on CD-R(W).
Best advice is to follow Sefy's guide under how to "DVD RIP"
meGUI Nero AAC encoding error
By ArtOfLosingMFZB in forum DVD RippingReplies: 4Last Post: 16th Aug 2010, 12:46 -
Nero Recode encoding problem
By goodmedo2003 in forum Video ConversionReplies: 4Last Post: 30th Apr 2009, 10:35 -
nero smart encoding
By m baqar in forum Authoring (DVD)Replies: 4Last Post: 27th Mar 2008, 05:13 -
nero 7 out of sync encoding
By sharky007 in forum Authoring (DVD)Replies: 1Last Post: 25th Jul 2007, 04:28 -
Question for Those Who are Familiar with Nero 6 or 7 on Encoding to MPEG-2
By wayney in forum Newbie / General discussionsReplies: 11Last Post: 13th Jun 2007, 19:35
