  1. I've got rmvb files with chinese subtitles, can it be removed? Or do I need to convert to Mpeg2 to be removed?
    Dec 2004
    Australia
    Chances are that your subs are hard encoded. If so they can't just be removed.
    Nov 2002
    Yep. If it's a part of the actual frame, then remove them will be extremely difficult and looks funny, as if that entire bottom section is blurry. So, forget it.
  4. thanks for your reply
