All of the video clips I load into FFMPEG will preview, and play (Making me think that all codecs are in place however......)
Only about 1/4 of the output presets actually work, when trying to process video.
Most of them, export a 0kb file, and show "Finished" in a succesfull manner, with no "Error info" that 0kb file, obviously not a valid video file.
A small few presets yield several different error messages, while 1/4 of them work beautifully.
I'd say the bulk of the presets, create a "Successful" 0 Kb file, that does nothing.
Oddly enough, in 1 scenario, I'm able to produce a divx output file correctly, however, using the same source file, I am unable to output a dv file, which I would think I shouldn't need a Codec for, with FCP, and QT 7 Pro installed on this machine.
OS X 10.4.5 & Most Recent FFMPEG
SuperReverb
Which presets cause the 0kb file? Which ones work well?
I had a similar problem when I first started using ffmpegX, but once I figured out which settings I needed, it worked like a charm...
I have been running into the same type of prolems. One of them I fixed by adding the DivX stuff. Many just leave me shaking my head in confusion. I think a new FAQ might be needed that addresses these things that are not covered (as far as I can tell) in the current FAQ(s). This would cover the questions that keep popping up on the forum. Just an idea...
TOny
Question - how to make ffmpeg use mjpeg codecs when it encounters 4CC code
By bf4648 in forum Video ConversionReplies: 0Last Post: 12th Oct 2011, 16:53 -
Need mencoder.exe and ffmpeg codecs
By swkenney in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2010, 19:41 -
FFmpeg Audio Codecs
By Klagar in forum AudioReplies: 10Last Post: 11th Nov 2010, 11:15 -
Disable internal ffmpeg codecs?
By McAlsop in forum Video ConversionReplies: 1Last Post: 23rd Sep 2009, 01:12 -
issues using codecs wmv9 and wma9.1 in ffmpeg
By jcor in forum LinuxReplies: 1Last Post: 15th Oct 2007, 08:27
