Hi there!
I have 5 hours of .mov files on my jvc cam (30gb harddrive). I would like to cut it using pinnacle studio.
what is the best way to convert it? Quicktime Pro?
And which format should I choose? avi or mpg or mpeg??
I intend to burn the video on dvds when I'm done with editing.
thanks alot!
Philip
From your questions, I gather that you know little about dvd capture/editing/authoring. It helps alot, if you know a little bit about what you are doing. You should plan on spending up to 8 hours reading guides, tutorials, and forums, before you even think about deciding what to do and how to do it..
First, Pinnacle Studio might work for you, but if you read through the forums, you won't find very many people with anything good to say about it. If you do use Pinnacle Studio, it has the ability to encode to mpeg1, or mpeg2, and others. If you want your end result to be a movie that will play on a dvd player, I suggest mpeg2. If you want it on your pc, it can be in any number of formats.
If you are planning on doing much editing, you should capture it as .avi or dv-avi, edit, then encode, if you want chapter menus you will need to create those (authoring), then you can burn to dvd.Rob
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 11:22 -
Dvd rip(HD) in mac - Mov,mpg,avi
By nimrodm in forum MacReplies: 3Last Post: 9th Feb 2010, 07:33 -
.avi to .mov conversion nightmare
By towarmforacoat in forum Video ConversionReplies: 4Last Post: 20th May 2009, 15:16 -
Having trouble with a conversion (mp4 / avi / mov / flv)
By loxley in forum Video ConversionReplies: 4Last Post: 23rd Feb 2009, 11:17 -
AVI to .Mov conversion
By HD_Shooter in forum MacReplies: 10Last Post: 18th May 2007, 07:45
