first off, my specs.
t-bird 800
128mb ram
win 98
40gb ata100 7200rpm ibm
60gb ata100 7200rpm maxtor
ati all in wonder radeon, 32mb...
What I'm looking to do is capture at probably the highest quality i can. then go down to mpeg1. using ati's mmc 7.1's tv program, i can capture avi (interlaced, and huge), mpeg 1 (fast motion blurs and gets blocky) and mpeg 2. Mpeg 2 seems to work best. i can capture at high resolutions without much of a problem. the problem comes when trying to convert. i can't open mpeg2's with tmpgenc. (tried to find a codec) i got "flaskmpeg" and i can convert mp2's to uncompressed avi's. it takes over 2 hours to do just a half hour of footage. then i have to convert again from the HUGE avi file. if anyone has any suggestions, reply or message me.
TA69
Unable to decompress your camera's image format cause a suitable codec is m
By cfairon in forum MacReplies: 2Last Post: 17th Jan 2011, 09:37 -
Does Converting MPEG1 2 MPEG 2 improve quality?
By purpleronnie in forum RestorationReplies: 10Last Post: 7th Aug 2009, 15:47 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
Recode Xvid/Ogg to PS3 Suitable Format
By mcompton69 in forum Video ConversionReplies: 2Last Post: 4th Sep 2008, 07:51 -
Dif / DV25 & Wav to MPEG (suitable for DVD burning)
By sevenleaf in forum Video ConversionReplies: 0Last Post: 21st Aug 2008, 04:33
