i have a sony dvd rw dw-u12a drive that came with my vaio which i have been using for about 3 or 4 years now and never had any problems reading or burning. but the other day i put in "in the mix" and my computer wouldn't recognize the disc. tried opening with several different programs and none of them could find anything. strange thing is that other dvds and blank media/burning i have no problem with. do i need a new driver or do i need to buy a whole new burner?
thanks for the help
it's probably using a codec you don't have installed
try vlc media player
try gspot -
Is this "in the mix" a commercial disc or one you burned yourself? Is it CD or DVD? Need more info here. Lots of potential issues.
If it plays on another PC, it's your drive. I'm guessing, but CDs use a different laser than DVDs. It could be a problem with the CD laser, assuming this is a CD.
Burners and even drives don't last forever. I have an old Pioneer DVD-ROM drive that's over 5 years old and it has lots of problems. It won't be much longer before it will have to be replaced. -
"in the mix" is a dvd that i rented and it played fine in my stand alone player along with my PS2. i just got done burning a dvd of some old home movies so i know the burner is working, also when i put in a blank disc the system recognizes it, as well as other dvds. i also had the same problem with the dvd "domino". i don't know if it will play on another pc as i only have one.
I have the same problem on two known good drives with the same movie (they get used every day). Disk plays in standalones but shown no files on it in the computer.
edit
this is pretty weird. Anydvd doesn't identify any special copy protection and dvd structure is corect but clone dvd and anydvd doesn't work. The anydvd ripper doesn't work either, but dvd decryptor seems to be ripping it (in the middle of it now) with anydvd running in the background, and oddly enough, dvd decryptor found and removed macrovision.
Edit again. With anydvd running in the background, ripped with dvd decryptor, then burned with clonedvd, I seem to have gotten a working copy. The computer still doesn't see any files on the original disk. this has got to be some sort of macrovision thing. I almost wonder if they have some sort of root kit crap going on.
Won't recognize disc
By totallylost1 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 9th Jul 2011, 19:57 -
Computer wonīt recognize DVD disk
By dexter30 in forum MediaReplies: 10Last Post: 4th Sep 2010, 15:52 -
Windows Media Player won't recognize srt file when multiplexed into an mp4?
By MR 3 in forum Video ConversionReplies: 2Last Post: 22nd Oct 2009, 12:44 -
Combined 2 discs into one, but disc won't play on dvd-player...
By StrobeLightEpileptic in forum Authoring (DVD)Replies: 5Last Post: 7th May 2009, 22:24 -
Divx Certified dvd player won't recognize 16x9 aspect ratio
By maca in forum DVD & Blu-ray PlayersReplies: 3Last Post: 30th Nov 2007, 13:48
