Just wondering if anyone had problems with backing up chicken little. I ripped it with dvdfab decrypter and it is the latest version. My comp either freezes at 10 % with dvd shrink or shuts down with dvd2one. Ive never had a problem backing up anything really before. Its pretty strange. Just looking for input . Thanks guys
Try putting it through FixVTS and/or running through vobblanker before opening in dvd shrink.
EDIT: You could also try ripping using the PSL2 Plugin for PgcEdit. I've never been able to figure it out though -
I had no problems in backing up Chicken Little. I ripped with the latest DVD FAB DECRYPTER then used DVD REBUILDER PRO.
Used CloneDvd2 and had no problems, the prog even said it found some Vob errrors and was fixing them. Perfect copy. I also used Dvd Decrypter and then used Recode 2 and had no problem. There was a strange cell that I used Vob Blanker to blank and then used Shrink and Recode 2 and there wasn't any issue then. These were some of the things I did and found that worked.
MovieDud -
I didn't even use the latest DVDFab Decrypter.
DVDFab Decrypter 2.9.6.8 & DVD Shrink 3.2, no problems. -
Thanks guys I got it done.
Life is like a pothole, you just have to learn to get around it. -
Hey, fantastic. Ya know I loved this movie as much as my little girl did. Have a great day!
MovieDud
Can't Backup Contagion
By aedipuss in forum Blu-ray RippingReplies: 0Last Post: 31st Jan 2012, 16:26 -
Chicken Bone
By budwzr in forum Off topicReplies: 10Last Post: 23rd Jan 2012, 10:01 -
How do you backup your o/s?
By johns0 in forum PollsReplies: 23Last Post: 6th Apr 2011, 05:31 -
Robot Chicken - Star Wars
By Simmons in forum Video ConversionReplies: 5Last Post: 24th Jan 2011, 19:12 -
Chicken Little Blue-ray backup to AVC/h.264 failes.
By anosis in forum DVD RippingReplies: 4Last Post: 8th Sep 2007, 11:32
