Hi,
This is my problem.
I have to attach 3 assets on a timeline. With Encore DVD 2.0 this is possible, but I have to insert a dipo to color or a dissolve between the assets.
What can I do?
I have to edit the sequence on an editor software before?
Or I can do transitions on the dvd authoring software?
Thank U
Alessandro, Italy[/b]
The Encore DVD 2.0 functions is just to save time to people who have a movie chopped so they dont have to render again everything into a whole big asset, but in your case, you said you HAVE TO get a transition effect beteewn them (while playing I understand), your only option is to edit your assets in a movie editor e.g. Premiere Pro combined with After Effects - for creating your transition- , so you can then join your 5 assets into 1 big movie (3 original assets plus 2 transitions). Now that asset will be good for you. Then you can use the transitions to be pointed with a chapter.
Drag and Drop Assets
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th May 2011, 04:37 -
DVD Maestro - Multiple assets, one VTS
By alfini in forum Authoring (DVD)Replies: 0Last Post: 10th Nov 2010, 01:32 -
How do I move assets from one project to another?
By Anaheim in forum MacReplies: 1Last Post: 1st Apr 2009, 23:14 -
Cannot add assets over network
By JohnRH in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 3rd Dec 2007, 22:57 -
Assets problem
By tandaman in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 7th Jul 2007, 18:25
