I need to 'mic up' a presenter at a show. He is doing a 3 hour presentation that I will be video taping. I need to capture the audio to sync up to pieces of the video later. What is the best way to do this? MP3 audio recorder worn by the subject? What kind of mic should I use? Wireless mic system hooked up to my Powerbook? Both? Help!
I don't want to spend mpre than $150-200 at most on this equipment.
Point. Click. Sigh.
If you have access to a good digital camcorder - hook up an external microphone to the speaker, and use the camcorder to capture the speaker's performance live.
Then, take the video you've captured and transfer it to your computer and edit/process/author from there.
I have done this for my son's rock band, and it's much better than hoping a wifi microphone works flawlessly, believe me.
Let me know if you have any questions, and good luck!
Cheers!
TTWC"I've got a present for ya!" - TTWC
How to restore audio on the right speaker on a video file
By Tintin11 in forum RestorationReplies: 8Last Post: 13th Nov 2010, 08:30 -
Edited sound jumps from speaker to speaker
By len hend in forum AudioReplies: 3Last Post: 23rd Jul 2010, 06:49 -
Audio out of only one speaker - ULead/EasyCap
By gmania in forum AudioReplies: 0Last Post: 16th Oct 2009, 22:03 -
Capturing live DirectX
By Kharza-kzad in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2008, 21:19 -
Audio coming from center speaker help
By faramith in forum AudioReplies: 6Last Post: 19th May 2007, 23:15
