  1. I'm currently running a 1.4ghz Athalon that is pulling about 1.55ghz right now....
    With Flask and DivX 4.11, I'm getting about 12-15fps encoding.
    When doing a standard 1.5/2 hr. movie..I'm looking about 4-6 hours...
    I've seen people doing a DivX in 2 hours flat even with 2pass...so my question is..
    I'm getting ready to upgrade....what's the best one to get for video encoding??
    Also..since compression is a numbers game, which ever one has the fastest math-co I guess would win right?
    Jason
    P.S. Also, posts your results!!
  2. well i don't know what the best CPU is for video compression, i might be able to help you still. i do alot of gaming on computers, and have alot of experience with computers. all computers work with numbers as sytem code, so i don't think the math co proccessor doesn't have much to do with what you're trying to do. i'd go with the best cpu you can afford, then over clock this shit out of it. try a socket a board, either asus or a-bit. as a general rule i prefer AMD, but that is up to you. anything around 1.8 to 2.0 is good, and then see how high you can overclock it.... i just made a very long story short, but if u need more help get me on aim: XxRedFactionxX
    -matt
    Jul 2001
    Maryland
    the more speed u can get the better.
    If u can get those 2.0 ghz, go for it.
  4. Actually, the math-co has EVERYTHING to do with it...you are crunching using Algorithms, and that's 100% math also based on the DCT.
    What I wanted to hear was what EVERYBODY ELSE IS GETTING OUT OF THEIR SYSTEM !!
    What??? no one here compresses video???
    Come on guys!! a little help here!
    Jason
  5. first of all INSTEAD OF YELLING because you didn't get an answer to the question you didn't as try searching. if you had done that in the first place you would have found this...
    https://www.videohelp.com/phpBB/viewtopic.php?topic=68060&forum=3
    <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>What??? no one here compresses video???
    Come on guys!! a little help here!</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    yes alot of people here compress video but not alot of people responde to dupe threads. there is ALOT of help here but it won't always be served to you on a platter and sometimes to get help you have to help yourself. like i said try searching next time.
    peace out,
    dumwaldo
    AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose.
