If you have two hard drives, you should source from one, and shrink to the other.
When I shrink video on a PC with a single 300GB drive, it takes about 18 minutes, but when I shrink video from a PC with two 200 GB drives ( source from C: and output to D: ), it takes about 10 minutes.
You already figured it out, the drive head is swinging between two places in that 300GB drive and thus take twice as long.
Originally Posted by SingSing
How long did the initial input take?
Is there any time savings in initially ripping the video to one drive, and then
shrinking the video with a different hard drive as the target, over just
ripping and shrinking simultaneously when one first inputs the video to the computer?
Or am I missing something? -
I'm happy for the OP's "discovery", but I think you'll find that the speed increase is actually to do with the utilisation of the IDE channels in this case. Similar speed increases can be seen by having a DVD-ROM on a different IDE channel to your hard drive.
If your source and destination folders are on the same drive, you can only do one operation down the same IDE channel at a time - read or write. So the same drive needs to read some info into RAM, feed the processor and then write back to the hard drive. However seperate IDE channels mean one can be constantly reading whilst the other is constantly writing. Hence the speed increase.If in doubt, Google it. -
1. For movie, I DVDshrink a movie without compression to a harddisk first. So, I can use VOBblank or MenuShrink to get rip of the warning, and unwanted material, then shrink to DVD5.
2. For digital cam, I transfer miniDV with a DVD recorder at XP, then author, and compile into a folder, then use DVD shrink to shrink it down to DVD5.
3. To get good video quality, I use DVDshrink with deep analysis. The long and intensive processing can run at max speed, if I remember to do it on a PC with two ATA133 harddisk, instead of the PC with single hard disk. -
Originally Posted by jimmalenko
It all depends on which drive is on which channel...period. Everyone knows that deep analysis is faster from the data on the hard drive vs. from the DVD in the optical drive.
Nothing new....moving on.
Video Degrading fast
By dwcjr69 in forum Newbie / General discussionsReplies: 5Last Post: 30th Dec 2011, 03:43 -
Video and sound to fast
By nadirsalaam in forum ComputerReplies: 1Last Post: 19th Aug 2008, 02:52 -
Video is going too fast
By wiksten in forum Capturing and VCRReplies: 0Last Post: 3rd Apr 2008, 14:27 -
Divx won't fast forward fast! What's wrong?
By Hank Kinsley in forum Newbie / General discussionsReplies: 8Last Post: 23rd Jul 2007, 19:49 -
.wmv movie file couldn't fast forward/fast seek?
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 20:43
