when playing a dvd it starts with chinese audio language and jap subs so i have to remove the subs and change the language to english everytime i start the dvd when stopping or turning off the dvd player it comes back to chinese audio and jap subs again how it c ould be saved so it will play with english audio language without subs without having to change tit everytime the dvd starts thank you very mluchhhh
Depends on your DVD player, but I suspect it's NOT possible, as in Asia they likely put the original language as "default", and English as "alternate".
thnaks for answering me is there a software or something with wich i can change the default language and subs thanks
Yeah, PGCEdit:
https://www.videohelp.com/~r0lZ/pgcedit/third_party/blutach/How_to_use_PgcEdit_new_macro.htm
This method allows you to jump to any menu or title on insertion of your DVD, setting the audio and subtitle streams of your choice and by-passing anything in your way (e.g. annoying FBI warnings, studio promos and Dolby Digital trailers) and having all the DVDs internal registers set exactly as they would be if the commands followed the original path. -
Of course, this would mean you rip the entire DVD to the HD, modify it, then burn the result to a new "copy".
thankd for answeing me guys no i wanna change the default language in a already burn dvd i don't re burn it again is that possible ?
Sometimes it is possible if the selection of the track is not specially set in the .ifo. I have had such a problem that in a number of DVD's my player will play the german track even if the first track is english. I found it depends of the language selection of the player menu - mine was set in german. So the player itself would play the german track if it exist, no matter which number it is. Then you need to set the menu of the player in english - so it will play the english track if it exist.
Multi-Language Subs
By DeathStalker77 in forum SubtitleReplies: 34Last Post: 29th Nov 2010, 00:13 -
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 17:34 -
Is it possible to get the subs to show up only when a different language
By rovierto in forum ffmpegX general discussionReplies: 4Last Post: 17th May 2009, 22:28 -
DVD Multi audio language-how to make it
By arvin in forum Authoring (DVD)Replies: 4Last Post: 10th Jan 2008, 16:33 -
Doesnt see Language Streams when ripping subs
By BobafettBH in forum SubtitleReplies: 0Last Post: 14th Jul 2007, 13:42
