try to open alcohol 120% it says
loading alcohol device drivers failed
emulation options and native driver interface of alcohol 120% will not be availble!
so in uninstall it and re install it again at first to works fine but after a a few minutes the same error occurs pls help realy need to use alcohol thnak you very much
PCIe/USB AVI Capture device with SVideo and fully functioning Win 7 drivers
By Spektre in forum Capturing and VCRReplies: 3Last Post: 23rd Aug 2011, 19:34 -
HD Pvr 1212 - device is not connected - can't use device in arcsoft softwar
By yoda313 in forum Capturing and VCRReplies: 9Last Post: 16th Aug 2009, 17:22 -
Help with loading vids pls!!
By lona in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 28th Jun 2009, 13:44 -
windows vista and device drivers
By toolady in forum ComputerReplies: 5Last Post: 24th Nov 2008, 21:33 -
Are the windows 2000 and XP device drivers interchangable ?
By SingSing in forum ComputerReplies: 2Last Post: 6th Mar 2008, 17:03
