  1. I tried to extract the DV audio file using Virtualdub, and I thought it'd be an easy job but obviously it isn't. The wave file I extracted was about 300mb for 1 hour of DV, but it is bad. I simply used direct stream, and If i use Full Process it gives me an error message says "No audio decompressor could be found to decompress the source audio format"
    What Should I do?
    also If I just drag the DV file into tmpgenc and try to convert it to mp2, though it does work, but the sound is null, so I dont get any sound at all.
    Please help me
    Apr 2004
    Miskatonic U
    Doesn't sound like DV to me. DV uses uncompressed PCM audio so the file should be much larger. Use g-spot to determine exactly what codec are dealing with (and missing). At a guess, I would say this is a VBR MP3 audio track.
    Read my blog here.
  3. in Gspot it tells me the video codec is dsvd or something and it cannot detect any audio codec to decompress the audio.
  4. Originally Posted by guns1inger
    I dont think it would be VBR mp3 cus I haven't converted the DV to anything else yet, the audio track is untouched. I used nerovision to capture the DV and I used the DV2 option.
    I can play the DV avi in Windows Media Player just fine or any other avi playback software like winamp, but Gspot tells me I dont have any codec installed to decompress the audio which is weird.
    I think it might be that I need a codec to decompress PCM format, can anyone please help me on this thank you.
  5. strange enough, If I drag the DV avi straight to CCE or TMPGenc they both work perfectly. but If I use avisynth then it would have problems with both Tmpgenc and CCE. Tmpgenc report an error with with no decoder to decode PCM sound.
    Sigh, what should I do
