This is a mystery. How can a Avi/Mpeg4 File have bits or pieces of other Mpeg4 files added to it from other Directories?. Is it some kind of Virus or a Hacker Program. I've downloaded some friends videos and when I played them, some how bits and pices of other Mpeg4 videos got mixed in it, One file had at lest 3 other Mpeg4 files mixed in it , ones that are on my Computer. I use ImTOO to convert the AVI/Mpeg4 files to Mpeg1. So far I can't get a Program to Play AVI/MPEG4 Files on my system. I use Win98 and Play Movies with Windows Media Player 7. I can Play AVI/MPEG4 Files with ImTOO Encoder Converter and they play realy slow and thats when I notice the Video having "Extra" stuff mixed in it. I've run AVG Virus Program many times..and nothing is found. So, I'm puzzled. Also I have Zone Alarm running when I'm downloading. So, Does anyone know what would Cause this?
Bring back "The Tripods"
It sounds like 'ImTOO' is your problem. Try using VLC media player to play your downloaded videos. It should play about anything. It uses it's own codecs. You may have codec problems. That might explain why they won't play properly. I hope you haven't installed any codec packs? For codec problems: DxMan and Codec Sniper.
You might want to do a virus scan. Eiwdo has a freeware scanner that works well: http://www.ewido.net/en/
Another is Trend Micro: http://housecall.trendmicro.com/
For freeware antivirus: http://free.grisoft.com/doc/2/lng/us/tpl/v5
Spyware; Spybot S&D: http://www.safer-networking.org/ and
SpyWare Blaster: http://www.javacoolsoftware.com/spywareblaster.html
All freeware and very effective.
How to compress MPEG4 files for emailing?
By robinh in forum Newbie / General discussionsReplies: 1Last Post: 21st Oct 2010, 15:00 -
Editing HDTV TS mpeg4 files
By kogoot in forum EditingReplies: 5Last Post: 25th Aug 2009, 19:57 -
No audio when converting m2ts files to MPEG4
By oldbassturd in forum Video ConversionReplies: 0Last Post: 1st Jan 2009, 15:24 -
What is the best way to edit MPEG4 files
By Paul W in forum Newbie / General discussionsReplies: 8Last Post: 1st Apr 2008, 11:32 -
Converting extracted DVD files to MPEG4
By lglrgl in forum DVD RippingReplies: 1Last Post: 25th Dec 2007, 11:25
