hi,,,i ve recently been useing convertxtodvd and it works great,,,,, but now i cant convert any mp4s with it anymore it gets like 10mins or so into the convertion then it says...error in converting or something on the bottom and it fills up the log screen with tons of yellow error mesages like every second..... and the program locks up after a bit. I am going insane what program will convert my mp4 for me???
also is there a program i should have for them i dont think any of my players recognices these as vid files??
Results 1 to 9 of 9
ok it looked like some other app was useing the vid files ment for quicktime but i switched them back. Now quicktime plays it but convertxtodvd still gives yellow error messages saying this mpeg4/quicktime is partialy supported and may cause glitches etc... before i even start the converter.
update i cant find super?? is there a full version im supposed to get...i can only find the free one is that good enoght i dont want any watermarks or limitations at all! -
ConvertXtoDVD obviously doesn't like all mp4 material. Try something else. Super is free, so you have nothing to lose.
Read my blog here.
ok to do dvd do i pick vob dvd compliant or vob under it??? where does the converted files go i cant tell??
ok nevermind i picked vob dvd compliant and the destination dir is the same as the input......BUT.........
How do i burn these....the files are coming out one .vob file per video.....i have tmpgenc dvd autor will i beable to use them or just burn them in nero....i need to put a butch of these vob file to fill up a dvdr -
Just a bit of feed back here for guns1inger and Boldrick
Cheers guys for your plain speaking explanation helped me a treat I’ve also downloaded Super which I didn't have worked the job a treat keep up the good work.
I can always find the answers to my problem within reading 4 or 5 posts on this site well done to all I've been coming here on and off for about a 2 years now and I always manage to solve my problem thanks to you guys so I think a donation is about due
P.s you got any solutions for dealing with difficult wives pmsl
sorry if this appears as spam it isn't inteded to be also please feel free to move and edit this post as you see fit modsMurphy was an Optomist -
Originally Posted by towbarDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Convert h.264 MP4 to DVD
By matthewjohn23 in forum Authoring (DVD)Replies: 15Last Post: 12th Jul 2014, 23:00 -
Best Way to Convert DVD to MP4
By kerb in forum Video ConversionReplies: 9Last Post: 18th Nov 2011, 13:28 -
ffmpeg help... convert mp4 to jpeg array, and back to mp4 - problem!
By SaskVideoMaker in forum Video ConversionReplies: 2Last Post: 4th Feb 2011, 04:53 -
Need advice on what to use to convert mp4.
By 82ndCowboy in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2010, 23:19 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 14:53
