First, let me explain that I am doing this as a learning process, simply to gain experience converting files from DVD to Divx, xvid and/or H264. So, please don't get angry with me.
I am working with a DVD of Franco Zeferelli's, Jesus of Nazareth." I ripped the files off of the DVD and have found the VOB file that seems to have the entire first disc on it. However, this file has five trailers at the beginning before the movie starts. If I bring this file into VDub the trailers begin to play and about half way through the fifith trailer the audio for the main movie begins playing but the video is still the trailer. From that point on the audio and video are significantly out of synch. If I choose any other VOB that doesn't have the trailers VDub seems to work with them fine. What am I doing wrong, or could this be an anomaly of this particular DVD?
Thanks for any light you can shed on this for me.
There are a couple of options.
Try loading the disc with DVD Shrink, then using re-author mode to create a new disc with just the main title in it. Write the results to your HDD, then try to work with the new VOBS.
or
Try a different tool - avi.net can load VOBs and might be able to extract just the title.Read my blog here.
DVD Shrink worked perfectly. Thanks for the advice. Now to figure out the proper settings for Super to encode to H264. I know there is a guide. I will have to revisit it.
Can't read disc/ripped VOB files
By koberulz in forum Newbie / General discussionsReplies: 11Last Post: 18th Oct 2011, 13:34 -
Trouble with Ripped DVDs/converting .VOB to .AVI
By research in forum Video ConversionReplies: 1Last Post: 15th Jul 2010, 15:42 -
Conversion issues with with 1. vob-file of a ripped dvd
By NSmooch in forum Video ConversionReplies: 5Last Post: 8th Jan 2010, 01:55 -
Ripped VOB #1 wrong aspect ratio, all others ok!
By silver007 in forum DVD RippingReplies: 8Last Post: 6th Jun 2009, 11:01 -
Converting ripped VOB to a .mov WITH SOUND....
By elmo7082003 in forum MacReplies: 3Last Post: 9th Oct 2007, 23:52
