I'm aware that you can use iMDb to look up the technical specs, but I sometimes find that from region to region, these specs can differ, particularly on ex-rental DVDs.
When converting DVDs to avis etc, it'd be great if there was a way to detect the actual aspect ratio of the DVD I'm converting - ie, 2:35:1, 1:85:1, etc (as opposed to just 16:9 vs 4:3 which is easy enough to identify by sight).
Is there any app that can do this, where VOB or IFO's or whatever on a DVD is concerned?
Thanks in advance for any help on this!
Results 1 to 9 of 9
What exactly would you do with such information? In short I don't understand the question I guess because I can't figure out what it is you are trying to do with that information.
Anyways it usually isn't that hard to "eyeball" aspect ratios. Most movies are either 1.85:1 or 2.35:1 with a few being 1.66:1 ... and then of course you have full screen 1.33:1
You could always try loading a VOB into VirtualDubMod and cut the black out and see what you have left.
For instance a 4:3 WS DVD with a 2.35:1 aspect ratio will be approximately 720x272 once you cut out the black above and below the image.
A 16:9 WS DVD with a 2.35:1 aspect ratio will be approximately 720x360 once you cut out the black above and below the image.
A 4:3 WS DVD with a 1.85:1 aspect ratio will be roughtly 720x360 once you cut out the black above and below the image.
Not sure on the math for a 16:9 WS DVD with a 1.85:1 aspect ratio but it is probably something like 720x420 give or take.
These are all for NTSC DVD by the way.
For a 4:3 encoded NTSC movie in a 720x480 frame divide 640 by the active picture height (ie, what's left after removing the black bars). For example 640/272 = 2.35.
For a 16:9 encoded NTSC movie in a 720x480 frame divide 853 by the active picture height. -
Originally Posted by FulciLives
2.35:1 aspect ratio after cutting all the black will be approx. 720x272 letterboxed and 720x363 anamorphic widescreen.
1.85:1 aspect ratio after cutting all the black will be approx. 720x345 letterboxed and 720x460 anamorphic widescreen.
1.78:1 (or 16x9 as we like to call it) will be 720x360 letterboxed and 720x480 anamorphic.
1.66:1 and 1.33:1 make no sence to go anamorphic, but letterbox for 1.66:1 would be approx. 720x385.
And all these numbers can vary slightly depending on how much black they decide to add to the sides of the image and how accurately they size their frame prior to encoding.
Darryl -
@dphirschler
I do appreciate the correct info but hey I was close enough especially with the 2.35:1 aspect ratio numbers LOL
I still don't see the point of this ... I mean a movie has an aspect ratio and that's that ... who cares exactly what it is ... you can't change it.
I suppose this is good info for those that want to shoot with a camcorder and "mimc" an aspect ratio by cropping/masking the image ... as long as you frame for it while shooting.
I remember a low budget horror film that was shot on video that came out around 1992 and it was framed at 2.35:1 by simply masking the top and bottom with black which was kinda neato looking at the time for something shot on video.
I guess it could be done by cropping the black from a VOB, but I thought there might be a simple indicator on the DVD that would carry the info. I got a tip that Media Player Classic would do so if you hit the "5" key on th numeric keypad while a VOB was loaded, but all that seems to do is to report ALL widescreen films as 1.78:1. Is there any other way (standalone app or otherwise) to get the AR from the disc?
Thanks for the help... -
Originally Posted by lyle waggoner
Open your VOB files in VirtualDubMod. Add the Null Filter. Use the Cropping tool to crop off the top and bottom black borders. Look to see how many scanlines are left. Use the equations I gave earlier to calculate the aspect ratio.
Oh wait, you're in Australia so you need PAL equations. Hold on a minute...
4:3 PAL: divide 768 by the number of scanlines.
16:9 PAL: divide 1024 by the number of scanlines. -
Originally Posted by jagabo
Anyhow, thanks for the PAL equations, much appreciated. -
Darryl
Change DVD aspect ratio
By drgt in forum Newbie / General discussionsReplies: 11Last Post: 4th Oct 2010, 21:45 -
Changing a DVD's Aspect Ratio
By soneman in forum Authoring (DVD)Replies: 11Last Post: 8th Sep 2009, 18:18 -
Does Panasonic AG-DVC62 have real or true 16:9 aspect ratio?
By nmeuncn in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 23rd May 2009, 17:15 -
DVD aspect ratio
By SWBisbee in forum Newbie / General discussionsReplies: 5Last Post: 17th Oct 2007, 23:52 -
Aspect ratio problem w/ True Lies
By videobruce in forum DVD & Blu-ray PlayersReplies: 9Last Post: 28th Jul 2007, 18:48
