Hello I am encoding my anime using winavi converter to convert from rm to mpeg1/2 or avi and when I burn my dvd with sonic and go watch it the subtitles are at the bottom and they are not centered the are more lowered down can anyone help me and thank you in advance.
Hey thanks for posting how do I check the ratio. I am going to try what you said and thanks for posting.
<rant>Seems like each and every one who tries to convert fansubbed anime for TV playback comes here with that question.
Why can't those fansubbers learn to properly position their subs within the TV safe area?</rant>
The only safe way to cure this is to add some black border around the picture to compensate for TV overscan, and I really think that's beyond WinAvi's scope.
/Mats -
exactly as mats said, it is TV overscan issue.
when you work with WinAVI, make sure you choose "Source Aspect Ratio" as 16:9 as well as to "Target Aspect Ratio", instead of default Auto Mode.
the final result video you play with your player would probably allow you to play in full screen or wide screen, at least my player allow me to change the playback ratio.
I have been using WinAVI to convert rm video all the time, no doubt it is the fastest encoding program around but at average quality. -
Yeah thanks for the replies. I Learned right now that I can make the screen size smaller so I am going to make it look like widescreen so that should fix the problem. Do you guys know what codecs(Video, audio) for the anime.
What codecs you should use? Whatever you want!
Though XVID seems to work well enough for Initial D Fourth Stage stuff that I've seen...
Anime encoding help
By carasy in forum Video ConversionReplies: 3Last Post: 28th Nov 2010, 19:07 -
Where to download free srt subtitles (Mostly for anime)
By lelouch283 in forum SubtitleReplies: 3Last Post: 19th Oct 2010, 07:53 -
Encoding anime
By prnoct90 in forum Video ConversionReplies: 3Last Post: 25th Nov 2009, 06:38 -
streaming anime no subtitles showing half the time/off screen
By thewhiteboy23 in forum Newbie / General discussionsReplies: 17Last Post: 18th Oct 2009, 13:46 -
Anime DVD to X264 with Staxrip - is it worth using the 'anime' setting?
By Emanef in forum DVD RippingReplies: 2Last Post: 8th Nov 2008, 16:31
