I have a Hauppauge WinTV PCI card with remote. I installed WinTV 2000. When I capture TV programs and burn it to DVD it is synce'd but it looks pixelated and the video hesitates. I captured the programs as mpeg and divx same problem. I used Pinnacle Studio version 9 with latest updates. I also used Sonic DigitalMedia LE v7 and the same problem. I also used TMPGENC Express same problem.
Any help would be greatly appreciated.
I am running Windows XP Media Center on a DELL Dimension 9100 with 1gig memory and 144 gig drive with 29gig free.
I hope you have *more* than a single 144GB drive in that system! As a rule, it is ALWAYS a good idea to capture to a NON-SYSTEM drive - and as a rule I usually capture to a completely different physical drive, not just logical.
I imagine that you are running other programs while attempting to capture as well, which will also adversely affect your captures.
Post back more info for further clarification, ok?
Cheers!
TTWC"I've got a present for ya!" - TTWC -
Thanks for the reply and help with not only this problem but the avi error question. As for my system. The 144gig drive is my system drive and I have 72gig free. I always stop all apps. via task manager before capturing. I think I'm going to add a 20gig drive to my system and see what happens. If this does not fix it what else would you suggest?
Need Help Capturing with VirtualDub and Hauppauge WinTV via Svideo
By ibAdam in forum Capturing and VCRReplies: 5Last Post: 21st Aug 2011, 22:01 -
Capturing from Hauppage USBLive2 WinTV device !!!
By imperialguy in forum Capturing and VCRReplies: 0Last Post: 23rd Jun 2011, 17:13 -
2000 DV's Capturing Per Year - Best Approach Help
By ilw in forum Capturing and VCRReplies: 2Last Post: 29th Dec 2010, 14:13 -
WinTV HVR 1800/1850 - interlaced capturing?
By justin81 in forum Capturing and VCRReplies: 1Last Post: 10th Jul 2009, 11:13 -
Need advice on Capturing Software for WinTV HVR-1800
By Smack2k in forum Capturing and VCRReplies: 5Last Post: 6th Jul 2009, 15:46
