I downloaded the demo version of WinDVD Recorder 5 and installed it onto my computer (see specs below). I can get the program to start but when ever i try to switch the source to the Ati Theater driver to capture a TV program to DVD the sound starts and before the video starts it boots me out to a Stop error blue screen with a nabtsfec.sys error. I requested support from Intervideo but they don't offer support for demo software so I bought it. Their support still leaves little to desire.![]()
I have unloaded the Ati software along with the WinDVD R 5 and reinstalled it all and still have the same problem. Other capture software I have work and in fact the WinDVR 3 demo works so I'm lost.
Another odd issue is that I ran the Ati PC Check program and its telling me that I don't have an Radeon Compatible video card in yet I have a retail built by Ati Radeon 9600XT AGP installed. What's that all about? I fired off an email with the screen capture of the PC Check results to Ati and have yet to see reply!!
Any help would be appreciated.![]()
PC Spec's
Asus P4P800 SE
P4 2.4 CPU
2Gigs Ram
Ati AIW 9600XT (Catalyst 4.12 with MMC 9.03, Directx 9.0c)
Creative Labs Live Value.
120 gig WD SATA
If you can, post the actual Stop code, it should be in hex like 0x00000000.
Thanks for your reply.
The file that caused the error is the one mentioned in my previous post. The blue screen also states that its a Page_fault_in _a_non_page_area.
The Stop error reads, Stop: 0X00000050 (0XF77D6FDE, 0X00000000, 0xAD77AFDB, 0x00000000)
Thanks again. -
I fixed the problem by totally wiping out my Ati software and drivers from safe mode then I reloaded the 8.8 MMC that came with the card.
Thanks anyway. -
SO now it works ?? and the moral is......
Hi, boys!
I have a blue screen with the oldest WinCoder (this is a light & powerfull ap.). The application job fine with my WEBcam, but with VideoIn - blue screen.
I have MSI nVidia FX5500 (AGP, TV Out), TV-Tuner + Video Input - ASUS MyCinema-P7131Dual, DirectX9.0c, WinXP Pro SP2 + All updates.
STOP: 0x00000050 (0x00000000, 0xB7F2D33D, 0x00000000)
NABTSFEC.sys - Adress B7F2D33D base at B7F26000, Date Stamp 41107dd0 -
& with last WinDVD Recorder5 too- TV,SVideo, Compozite, but not with InterVideo Home Theater.
(for out of trial: see in Google for ackTeam.ws)
This is a deeeep bug...!
Standalone recorder that doesn't stop recording in response to VHS snow?
By thx1138d2002 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 2nd Dec 2011, 22:55 -
Can't Stop Magnavox DVD Recorder TITLE Page from Playing Recording
By Novice20 in forum Newbie / General discussionsReplies: 19Last Post: 7th Sep 2011, 11:00 -
Black screen system32\DRIVERS\pci.sys Error with XP
By neworldman in forum ComputerReplies: 1Last Post: 8th Dec 2010, 15:34 -
BSOD STOP : 0x0000007E - tcpip.sys
By Jo The Veteran in forum ComputerReplies: 29Last Post: 28th Jul 2009, 02:38 -
Impossible installing XP on my compaq c571nr. iastor.sys?
By liquidsub in forum ComputerReplies: 2Last Post: 11th May 2008, 18:10
