Which file formats allow you to render a movie and preserve transparency so I can then take that movie and import it later on onto other video clips
i need to preserve the transparency though so i can overlay it
QT targa and png are two easy ones to use -- there are several others ... what are you using to render a movie?
render with what ? render could mean a lot of things ..
in other words - are you sure it has transparency to begin with ?
are you doing composting? cgi ? , film transfers with a scanner ?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
yes it has transprancy to begin with, i think the alpha channel is transparent if i remember correctly
well then render it in the same format as it is most likely lossless compression ...
How to convert .mov (with alpha video 32bits) into .flv with transparency ?
By akinnzip in forum Video ConversionReplies: 1Last Post: 8th Jun 2011, 10:41 -
Preserving transparency in morphed video with FantaMorph
By Raniburger in forum EditingReplies: 0Last Post: 12th Mar 2008, 18:08 -
DivX Subtitles: can u change the font/transparency in the .SRT file?
By chin569 in forum Newbie / General discussionsReplies: 11Last Post: 7th Nov 2007, 11:26 -
DVDauthorGUI gifMasks transparency?
By chewie8008 in forum Authoring (DVD)Replies: 10Last Post: 19th Jul 2007, 14:31 -
transparency effects on XP
By 4m in forum Newbie / General discussionsReplies: 1Last Post: 23rd May 2007, 15:01
