    Jun 2001
    Haifa, Israel
    Hi
    Help much appreciated
    I have a Win XP SP2
    For several days suddenly I can't import video files into Windows Movie Maker , I get the following error message : "C:\Tmp\ToLoad\2006_03_14\MVI_2387.AVI could not be imported. Unspecified error"
    I have all video codec installed
    All kinds of video files (divx, mpg, avi. wmv....) are working ok with Window Media Player and all others players
    Any suggestion?
    Rafi
    Feb 2004
    Australia
    Is that coming up when you run the application ?
    If so , it is possible you have created a project sometime before hand and since then the file has either been removed , or corrupted .
    Corrupted file can cause this to happen , so check that reported folder , if file exist's , remove it , and try again .
    Alway's when completing task's in movie maker , clean out previous project's if nolonger required .
    Next thing if that fail's is to uninstall all codec's , such as xvid , divx , ac3_filter's , ffmpeg ... nail them all .
    Restart pc , and see if error appear's , if not , then one of those had developed a problem , most likely to be caused by ffmpeg .
    Final , if you have movie maker , downloaded or otherwise available on cd , try running it , then reboot pc .
    This can repair the program's issue should it be a problem in itself .
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    I suggest a better editor anyway.
    http://www.kiva.org/about
  4. Member zoobie's Avatar
    Feb 2005
    Florida
    perhaps a different avi that wmm doesn't like
    try the free windows media encoder
