I finally got the SVI to DVD system working nicely but I have run into trouble when I try to rip a DVD to xvid or divx. The program chuggs along for about a minute and a half then goes "BING" and says that the job is finished. All I have is an empty AVI file. Here's the info read out:
Encoding started on Wed Mar 22 05:53:52 PST 2006
MEncoder dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec not found
CPU: PowerPC
libdvdread: Couldn't find device name.
Reading disc structure, please wait...
There are 4 titles on this DVD.
There are 29 chapters in this DVD title.
There are 1 angles in this DVD title.
DVD successfully opened.
success: format: 0 data: 0x29800 - 0x27000
MPEG-PS file format detected.
VIDEO: MPEG2 720x480 (aspect 3) 29.970 fps 9000.0 kbps (1125.0 kbyte/s)
[V] filefmt:2 fourcc:0x10000002 size:720x480 fps:29.97 ftime:=0.0334
Opening audio decoder: [liba52] AC3 decoding with liba52
No accelerated IMDCT transform found
AC3: 2.0 (stereo) 48000 Hz 192.0 kbit/s
No accelerated resampler found
AUDIO: 48000 Hz, 2 ch, s16be, 192.0 kbit/12.50% (ratio: 24000->192000)
Selected audio codec: [a52] afm: liba52 (AC3-liba52)
xvid: using library version 1.2.-127 (build xvid-1.2.0-dev)
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=640 h=352]
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 480 (preferred colorspace: Mpeg PES)
The selected video_out device is incompatible with this codec.
Also try adding the scale filter, e.g. -vf spp,scale instead of -vf spp.
VDecoder init failed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2))
Building audio filter chain for 48000Hz/2ch/s16be -> 48000Hz/0ch/s8...
Building audio filter chain for 48000Hz/2ch/s16be -> 48000Hz/2ch/s16be...
VDec: vo config request - 720 x 480 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
SwScaler: FAST_BILINEAR scaler, from Planar YV12 to Planar YV12 using AltiVec
videocodec: XviD (640x352 fourcc=44495658 [DIVX])
xvid: par=0/0 (vga11), displayed=640x359, sampled=640x352
xvid: CBR Rate Control -- bitrate=1213kbit/s
Tried what you said with the same result. Chugged for about a minute then it said FINISHED. I tried some other settings and was told that FFMPEGX doesn't allow VIDEO_TS input.
Divx/Xvid problem in Virtualdub (not mod)
By leeqk in forum Newbie / General discussionsReplies: 14Last Post: 11th Apr 2010, 02:18 -
Problem exporting xvid/divx with Premiere CS4
By moogleii in forum EditingReplies: 2Last Post: 23rd Mar 2009, 20:18 -
Xvid and Divx playback problem on TV set
By herbapou in forum Media Center PC / MediaCentersReplies: 3Last Post: 7th Sep 2008, 13:17 -
Vob to Xvid in autoGK or Divx Converter problem
By arcangel14563 in forum DVD RippingReplies: 1Last Post: 19th Nov 2007, 18:11 -
Problem with Divx/Xvid with Winamp and Virtualdub
By mekuka_pinasem in forum Software PlayingReplies: 5Last Post: 1st Aug 2007, 12:41
