I use a Nokia CA-53 Cable to connect my N90 to my PC and recently i updated the Nokia PC Suite and the cable driver form the Nokia website and had a problem with the connection between the PC and the phone so i decided to uninstall and re-install
PC suite installed fine but when coming to do the driver for the cable i started having problems, what happen is you install the PC suite then it will ask how you are going to connect the phone so i choose cable then it will ask you to plug in the phone and say that the drivers will begin installing this process doesn't seem to proceed any further so i tried the downloaded driver from the site ok it installs fine but when i plug the phone in a get a warning saying that a unknown device has been detected, if i check the prpperties of the device it says that there are no drivers installed, i have tried using the Windows troubleshoot and help but i was told that it could not find an answer after trying all the things it listed.
Does anybody have any idea as what could be causing this problem?
Results 1 to 1 of 1
Problem Connecting PS3 (Army Of Two)
By Squid_uk in forum Off topicReplies: 1Last Post: 19th May 2008, 11:17 -
Problem Connecting PC to TV via HDMI
By M.AD in forum Media Center PC / MediaCentersReplies: 1Last Post: 23rd Feb 2008, 16:05 -
Nokia N93i Firmware Problem
By Squid_uk in forum Off topicReplies: 0Last Post: 25th Sep 2007, 06:50 -
Problem connecting PC and LCD tv
By rozenokolis in forum DVB / IPTVReplies: 1Last Post: 26th Jul 2007, 16:37 -
Converting AVI to either MP4 ofr 3gp on Nokia 5300 phone - a/v sync problem
By johnbdrysdale in forum Video ConversionReplies: 17Last Post: 13th Jul 2007, 21:56
