I was wondering if and how, you can make copies/back-ups of an interactive DVD? Can anyone help me out with this?![]()
Results 1 to 15 of 15
What do you mean by "interactive DVD"? If you're talking about something like Madagascar, where the DVD launches something on your PC when you put it in the drive, here's how (in a nutshell):
- Rip the DVD using DVD Fab Decrypter or similar DVD ripper
- Go to My Computer and right-click on the DVD, then select "Explore"
- Copy out all the files aside from VIDEO_TS and AUDIO_TS to a folder on your desktop, then right-click on the folder and select "Properties" - note the size down
- In DVD Shrink (or your preferred application), make sure you leave enough space free to put the files in again - do this by setting the output file size/media size
- Encode the DVD, but make sure it outputs as files (VOB, IFO etc.) and not an ISO
- Launch your DVD burner, Nero for example, and drag-and-drop the files produced into the VIDEO_TS folder
- Place the files you put in the folder on your desktop back where you found them, most likely in the root of the DVD (where AUDIO_TS and VIDEO_TS live)
- Burn, and it should work fine
That's how I did it, but there are probably more elegant solutions out there! -
If you mean Video DVD based "games", then yes, as long as you don't reauthor. Backed up "Who wants to be a millionaire?" successfully with DVDShrink only. No reauthor, just full disc shrunk to DVD5
(One helluva piece of authoring on that disc!)
/Mats -
I've done a few games (Dragon's Lair, Space Ace) as full backups, and they came out great (rip to iso, burn from iso).
Could you please give me more details on this? Maybe a step by step thing???
What is in the source folder?Originally Posted by Cindee
/Mats -
I'm clicking on the DVD burner in my F: drive as my source folder. Also tried to copy everthing to a folder on my desk top and put that as the source folder, but that didn't work either. I'm at a loss. I don't know what else to do???
Read ISO, Write ISO.
Use either SL or DL discs as needed.
The end.Want my help? Ask here! (not via PM!)
What do you mean by "Read ISO, Write ISO." Is that a file here in this forum that I can read? How do I do that?
Ah. Source drive.Originally Posted by Cindee
Well, if DVDFab Decrypter says it's not a Video DVD, it's probably a data DVD, just intended for computer use, so no Video DVD backup methods/tools apply.
The best you can do is do as LS says, DVDDecrypter ISO read, ISO write. That's 2 things you do with DVDDecrypter. First, you tell it to read the original to ISO file, then you take out the original, insert a blank disc, and set DVDDecrypter to "ISO Write".
But if it's a commercial game, be aware that it probably will contain anti backup mechanisms, so the copy will most likely be useless anyway.
/Mats -
Oh!!! Thank you! Thank you! That makes so much more sense. I will try this and let you know how it works.
Ok.....ran into problems once again. Of course. I did just what you said. But now DVD Decrypter is saying "Disk is not a DVD" So I guess it is just a disk for your computer. Not the DVD. My BIG mistake!! So what can I do now to make a copie of this?
Most burn apps have a disc backup option.
But doesn't DVDDecrypter backup data discs to ISO?
I use DVDDecrypter to backup PS2 DVD - Can't be much different to a regular data DVD?
/Mats
looking 4 FX creator 4 dvd/br interactive menus
By cesarin in forum Authoring (DVD)Replies: 0Last Post: 30th Dec 2011, 08:55 -
Interactive DVD Authoring Advice please
By Arron in forum Authoring (DVD)Replies: 1Last Post: 26th Apr 2010, 07:48 -
Interactive DVD menu
By aloram in forum Newbie / General discussionsReplies: 5Last Post: 16th Jan 2010, 01:10 -
Creating a DVD with Interactive Menu
By magus2008 in forum Authoring (DVD)Replies: 11Last Post: 20th Nov 2008, 06:33 -
Interactive DVD`S
By natty in forum Newbie / General discussionsReplies: 18Last Post: 5th Feb 2008, 02:58
