i'm having the darnedest time trying to encode for my dvp642 using ffmpegx, and more specifically the mpeg4 (avi) ffmpeg codec. no matter what i've tried so far, the file flickers across the top half of the screen, jumping at a faster than normal play rate. the same thing happens if i use mencoder (mpeg4 avi).
however, if i use xvid, the file plays fine. though the dvp642 can be picky about xvid, so i'm trying to avoid it for the most part. the player also doesn't have any problems with files encoded using the divx3 present, toast 7's divx or handbrake's ffmpeg.
but for what i'm trying to do, i'd really like the flexibility of ffmpegx's mpeg4 settings. anyone have any ideas on how to make this work?
much appreciated.
In my admittedly limited experience, here's what works best for me. Handbrake with avi chosen for output always plays back on my dvp642. It produces divx 5.0 files using ffmpeg. Using ffmpegx, I get divx 4.1.2 files, which don't always cut it. Of couse Handbrake only works with DVDs or Video_TS folders.
Sometimes the light at the end of the tunnel is a train. -
Both use MPEG-4 libavc, although the fourcc and default encoding settings may differ. Neither uses DivX® (4.1.2/5.0) from divx.com, as it isn't free (open) software.Originally Posted by ThisistheEdge
Thanks for the clarification, Case. The 5.0/4.1.2 numbers are what I see with get info in QT Pro. Don't know why the DVP642 likes one better than the other, but in my case it does.
yeah, handbrake pretty much rocks my socks for video_ts encoding. however, i would still like to figure out if it's possible to user the mpeg4 codec to get a dvp642-compatible file, for general reference and because handbrake is giving me some trouble on a particular job (it's encoding a much lower bitrate than i tell it to for some reason).
on my tv, the divx3 preset is not unacceptably bad in quality, but if can get the improvements from the later versions, so much the better.
thanks for the input. -
i'm going to hijack my own thread to ask about the above mentioned bitrate problem, as it is tangentially related to my original question. i've tried just about everything i can think of, and for some reason, the files i'm working on are being encoded at a lower bit rate than i specify.
whether i use handbrake or ffmpegx, the bitrate drops significantly. for example, i've set the bitrate for all files at 1150kbps, but when finished encoding, the actual bitrate is anywhere from 609-918kbps.
i've even converted the files to .DV before encoding to avi with no effect on the on the final product.
any ideas?
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 08:45 -
New to ffmpegX A few questions about settings ect!!
By HELLZWINDSTAFF in forum ffmpegX general discussionReplies: 5Last Post: 2nd Jul 2009, 00:54 -
FfmpegX x264 settings
By bvdw in forum ffmpegX general discussionReplies: 4Last Post: 20th Jan 2009, 14:23 -
Philips DVP642 How to restore my region settings
By dgreekman in forum DVD & Blu-ray PlayersReplies: 3Last Post: 15th Jan 2009, 11:16 -
Settings in ffmpegX for odd size .avi files
By sknox in forum ffmpegX general discussionReplies: 2Last Post: 8th Jul 2007, 23:32
