Results 1 to 10 of 10
    Mar 2006
    how can i or what tool can i use to shorten an mpeg movie so that i can burn to cdr-vcd
    i did look around this and other sites, i dont know enough about this stuff to figure it out for my self.
    thanks for any help
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Take a look through the HOW TO - CONVERT section. Then just search on mpg to vcd conversion.
    Google is your Friend
    Mar 2004
    Boise, ID
    Interesting... I just typed in MPEG to VCD in search tool, and came up with 35 pages of information. Really don't mind helping people, but I sure as hell won't do all of the work for you... Search, read, then come back and I'll be happy to try to answer any questions that you have.
    Rob
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    VCD is a very tight specification. Read WHAT IS, VCD top left. On a regular 700 MB CD, you can fit 79-80 minutes of video in VCD format.
    /Mats
    Mar 2006
    is that always your answer,
    dont reply if your gonna be a dik, i still did nt find anything and i dont think you found it eather you just wanna be a know it all
    whatever
    let reread your post lmao
    "Interesting... I just typed in MPEG to VCD in search tool, and came up with 35 pages of information. Really don't mind helping people, but I sure as hell won't do all of the work for you... Search, read, then come back and I'll be happy to try to answer "
    what a bitcch.........lol
    Feb 2004
    Australia
    Ok , found where this one was hiding .
    If user's pm me , please copy the web link from the adress bar ... it take's time locating these thing's ... and would be much appreciated .
    There are a few tool's capable of clipping mpeg's , most are commercialware , which place's them in the junk bin , apart from a few , like ulead video studio ... If you want to cover a complete range of idea's dealing with mpeg's , then lookup ulead video studio 7 , 8 or 9 , the se edition's in ebay , there cheap .
    Version 9 can produce lpcm audio , and convert mov , asf , wmv (unprotected) .
    All version's can clip , version 7 need's only 2 updated dll's if using xp with sp2 , version 8 has an 80mb download to fix filter's , v9 seem's ok .
    So why bother with tool's that only handle clipping , for the same money , you can get more ...
    It is the best tool for frame rate conversion's ... never a problem with nstc to pal and back .
    The program's I personally hate are those developed as freeware , and as soon as the bug's are fixed from user input , they go commercial ... in my book it's back stabbing user's , and is why I push freeware ... and support it whenever I can through guide's and helping newbies when they get stuck .
    The free method is using virtualdub to frameserve the mpeg , choosing your start and end frame's , then frameserve to bbmpeg (as avi) , or quenc (as avs) ... bbmpeg has better setting's and control over output quality .
    Of course this envolve's that nasty term "re-encoding" , but it can't be helped .
    An explaination of such process can be found here :
    https://forum.videohelp.com/viewtopic.php?t=270071
    Should this mpeg be of mpeg2 type , then this is even simpler , and free .
    The process involve's batchdemux to seperate the video and audio stream's .
    Besweet to re-encode the audio to ac3 .
    Then open the mpeg m2v stream in vdub , and locate the frame you need to clip at .
    Write this down in a text file called celltime's .
    Run ifoedit , goto author dvd , load m2v video , load new ac3 sound , load cell time's text file , choose output folder , and let it rip .
    All you need do after this is done is to open the produced vob in vobedit , sellect demux , choose via cell id , sellect demux complete title set , choose new folder for output , and go .
    It will be perfectly split where you needed it to be .
    This can also be used to split video at I frame's , as someone asked this before ... however I am not the person who designed this program , so it is anyone's guess if this will be entirely accurate .
    If I was , I would have guaranteed such feature's .
    For info regarding mpeg2 spliting , read this :
    https://forum.videohelp.com/viewtopic.php?t=291744
    I know this is going to be alot to take onboard ... too learn I mean , but after a while it become's second nature ... after all it hasn't cost you a cent for the tool's ... unless you decided you couldn't live without ulead video studio "se" being part of you collection .
    Mar 2006
    wow thats great thank you
  8. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    The confusion is in your use of the term "shorten", what you are really wanting to do is "EDIT". In which case there is also a HOW TO - EDIT section.
    Mar 2004
    Boise, ID
    whatever
    Here is the search I did from this site. While all of these won't pertain to your situation, I guarantee that quite a few will. I'm not the dik, you are. I'm just trying to get some lazy people to do a little work on their own, before they start asking for somebody to do everything for them. That is how I learned, and how most of the rest of us learned. I'm happy to share what I know, but I'm not going to come to your house, hold your hand, put the dvd's in for you, and run the programs... From your spelling, I gather that you are either very young and inexperience, or uneducated.
    INDEX F.A.Q. SEARCH LATEST POSTS Rules Register Profile Private messages Login
    Search all forums: Advanced search
    Search found 3287 matches
    Click here to search for VCD to MPEG using Google in our Forum.
    Forum Index
    Author Message
    Topic: Watching JPG's via DVD Player
    SingSing
    Forum: DVD Authoring Posted: Mar 22, 2006 11:35 Subject: Watching JPG's via DVD Player
    The DVD player you have can't dsiplay the jpg you burned, it treat them like mp3 files, and shows their names, you click on it, and the player figured out they are mp3, and so nothing happened.
    A D ...
    Topic: shorting mpeg
    setkill
    Forum: Newbie / General discussions Posted: Mar 22, 2006 11:07 Subject: shorting mpeg
    Interesting... I just typed in MPEG to VCD in search tool, and came up with 35 pages of information. Really don't mind helping people, but I sure as hell won't do all of the work for you... Searc ...
    harley2ride
    Forum: Newbie / General discussions Posted: Mar 22, 2006 09:56 Subject: shorting mpeg
    Topic: Basic VOB editing software
    Bjs
    Forum: Newbie / General discussions Posted: Mar 21, 2006 12:22 Subject: Basic VOB editing software
    The basic's :
    Ifoedit , basic authoring
    vobedit , stripping and joining of vob's
    Batchdemux , demux mpeg2 file's
    Besweet , conversion of audio
    Transition's for dvd menu , handy
    Dvdauthorgui , ...
    Topic: How to make use of a 80min CD-R to burn VCD?
    AlecWest
    Forum: (S)VCD Authoring Posted: Mar 20, 2006 09:20 Subject: How to make use of a 80min CD-R to burn VCD?
    Nero will recognize a VCD compatible MPEG file and convert it into a somewhat smaller file (AVSEQ01.DAT) and create the appropriate required directories (and other required files) needed to recognize ...
    Topic: FFmpegX newbie questions mostly about VCD
    pdv1956
    Forum: ffmpegX general discussion Posted: Mar 20, 2006 08:14 Subject: FFmpegX newbie questions mostly about VCD
    In my Windows past I did a lot of TV recordings, saved as AVI (DivX or XviD) 4:3 and 16:9. All of this I now want to convert to VCD PAL 352x288 with Black Borders. (no actual VCD on cd, but keep the f ...
    Topic: Not able to burn movie onto CD
    redwudz
    Forum: Newbie / General discussions Posted: Mar 19, 2006 18:57 Subject: Not able to burn movie onto CD
    First, what format is it presently? VirtualDub is mainly for AVI, not MPEG. If it's MPEG, then TMPGEnc is one program you can use to split it. Cuttermaran is a freeware editor that may do better. If y ...
    Topic: mpeg to video_ts
    chris_j11
    Forum: Newbie Conversion Posted: Mar 19, 2006 12:58 Subject: mpeg to video_ts
    i normally convert my avi to vcd / svcd / dvd using tmpgenc and i'm quite happy/satisfied with it
    now i'm looking for a software that will convert mpeg1/2 into video_ts w/o any quality loss (if possi ...
    jimmalenko
    Forum: (S)VCD Authoring Posted: Mar 19, 2006 06:20 Subject: How to make use of a 80min CD-R to burn VCD?
    AlecWest
    Forum: (S)VCD Authoring Posted: Mar 18, 2006 12:57 Subject: How to make use of a 80min CD-R to burn VCD?
    I tried to burn a 716Mb mpeg using a 730Mb CD-R, i thought it should work, but i failed to play the disc on either PC or DVD player. Is there anything i have to pay special attention to? I use NTI CD ...
    Topic: Avi Files Onto DVD - How?
    Bjs
    Forum: Newbie / General discussions Posted: Mar 18, 2006 10:23 Subject: Avi Files Onto DVD - How?
    Do yourself a favour .. go download mad right now and grab all the free tool's you can before they disappear ...
    Depending on the avi's , and the capabilities of the player , you can use super to e ...
    magicnic22
    Forum: (S)VCD Authoring Posted: Mar 18, 2006 08:48 Subject: How to make use of a 80min CD-R to burn VCD?
    Topic: how to add subtitle mpeg2 to mpeg1
    Bjs
    Forum: Subtitle Posted: Mar 18, 2006 07:36 Subject: how to add subtitle mpeg2 to mpeg1
    Try frameserving the dvd from virtualmod to bbmpeg ... look in guide's section for my guide's , I have mentioned the method for dealing with multiple vob's .
    As for subtitle's for vcd's .. I though ...
    thecoalman
    Forum: Newbie / General discussions Posted: Mar 18, 2006 06:20 Subject: Avi Files Onto DVD - How?
    Am I correct in understanding that for what I want to do, I will need additional programs? I get the gist of what I need to do. I need to encode my avi files (to vcd it seems) so that they will pl ...
    Topic: Need advice on a DVD/VCR combo unit
    RDS1955
    Forum: Newbie / General discussions Posted: Mar 14, 2006 08:10 Subject: Need advice on a DVD/VCR combo unit
    I work in a 911 center here in the states... We have a TV set that is on constantly, 24 hours a day watching the news.After business hours, (5PM through to 7AM next morning during the quiet periods th ...
    Topic: video freezes near end after being converted from AVI to s/vcd(mpeg)
    vengeancedemon
    Forum: Newbie / General discussions Posted: Mar 12, 2006 23:23 Subject: video freezes near end after being converted from AVI to s/v
    Hi there,
    I am starting off with an AVI/Divx file, and converting to MPEG(s)vcd. I am converting these files using "Main Concept MPEG Converter". Everything works fine up until about 2-3 minutes from ...
    Topic: SuggEst me ur best programms
    jimmalenko
    Forum: Newbie / General discussions Posted: Mar 11, 2006 19:14 Subject: SuggEst me ur best programms
    what r the BEST
    https://forum.videohelp.com/viewtopic.php?p=1388992#1388992
    1.Create VCD from any format (with fast speed and good quality)
    I like 2.DVd 2 VCD conversion
    3.fit dvd9 to dvd5
    I kn ...
    Topic: I can only fit a 1hr AVI on a DVD !
    InXess
    Forum: DVD Authoring Posted: Mar 11, 2006 02:22 Subject: I can only fit a 1hr AVI on a DVD !
    BS, you're trying to find a graceful way out from the trap you TOO easily fell into.
    Now, a word from:
    But, whatever shortcomings
    http://www.computervideo.net/aug04-2.html
    for your refere ...
    Topic: Fixing MPEGs
    the_scarlet_pimperne
    Forum: Newbie / General discussions Posted: Mar 11, 2006 00:48 Subject: Fixing MPEGs
    piano632
    I tried using the MPEG GOP fixer on MPEG-VCR on both the source file and the VCD file.
    The amended source file produced a length at 2'42'' (similar running the MPEG through TMPGenc) an ...
    Topic: What can I do with an AVI file?
    albi123
    Forum: Newbie / General discussions Posted: Mar 10, 2006 18:01 Subject: What can I do with an AVI file?
    Hello,
    I have a POwershot SD450 Digital Camera - it takes avi files in movie mode. I'm kind of familiar with mpeg, vcd and svcd but I dont' know what is an avi and what can I do with it and what i ...
    Topic: How to rip the video from (S)VCD CDs or BIN/CUE images
    DereX888
    Forum: User guides Posted: Mar 08, 2006 20:00 Subject: How to rip the video from (S)VCD CDs or BIN/CUE images
    If you are going just to *watch* the file on your computer, why detruncate it back? Just copy the .dat file from your vcd to your hdd as is, any only if you are going to use the source mpeg file for i ...
    Topic: Fixing MPEGs
    Forum: Newbie / General discussions Posted: Mar 07, 2006 15:31 Subject: Fixing MPEGs
    Hey Forum
    I am new to video encoding and have been trying to fix an MPEG. When the file is in its original state the size is stated at 343Mb. When the file is played in any player (winamp or media ...
    Topic: Help with slide show CD
    Bjs
    Forum: Newbie Conversion Posted: Mar 07, 2006 11:35 Subject: Help with slide show CD
    Seing's how it's only under 28mb's , and in vcd format .
    Use vcdgear to extract the mpeg , dont use the fix error feature .
    Then open it in virtualdub , if audio error , ignor it (that's if it has ...
    Topic: Converting rm video files to DV
    vipdigitalmedia
    Forum: ffmpegX general discussion Posted: Mar 06, 2006 00:02 Subject: Converting rm video files to DV
    OK I have tried to convert my .rm files to DVD and i select DVD mpeg2enc and select encode with mplayer..in the video window i selected 4:3 and DVD and check: "encode video" and had no luck....
    and ...
    Topic: Compress Vob .. AVI .. MPG .. Wm ( SPEED & Quality )
    yoda313
    Forum: DVD to AVI, MP4, WMV, S/VCD Posted: Mar 05, 2006 10:04 Subject: Compress Vob .. AVI .. MPG .. Wm ( SPEED & Quality )
    Well windows movie maker 2 will do that (freeware but requires at least win2000 and maybe XP only for the newest version).
    But i think you're limited to wmv output.
    You can use virtualdub or ...
    hech54
    Forum: Newbie Conversion Posted: Mar 05, 2006 05:21 Subject: Help with slide show CD
    If it is already in VCD format....the original pictures(jpeg, bitmap etc etc) are gone. They are now part of a mpeg video file.
    Topic: can you play vcd's on a dvd?
    ZippyP.
    Forum: Newbie / General discussions Posted: Mar 04, 2006 15:31 Subject: can you play vcd's on a dvd?
    no I mean... put a vcd file onto a dvd and get it to play.
    Follow this guide (as above), skip the extraction section and go straight to the Author section if you already have a VCD mpeg.
    Topic: Ripped audio shorter than video file?
    newshoes
    Forum: Audio Posted: Mar 02, 2006 21:18 Subject: Ripped audio shorter than video file?
    Hello Group,
    Ok, I've read 10 pages of threads and didn't see my q/a posted...
    I've got a music video file (mpg).....
    It runs fine in many players...
    But when I rip the audio out to listen to ...
    Topic: no audio when using eazy vcd
    jkayner
    Forum: DVD to AVI, MP4, WMV, S/VCD Posted: Mar 02, 2006 08:20 Subject: no audio when using eazy vcd
    ripping latest bat man movie to mpeg. the video comes through fine, but no audio is present at all. Any suggestions or tricks?
    Topic: VCD to VCD
    ZippyP.
    Forum: (S)VCD Authoring Posted: Mar 01, 2006 21:49 Subject: VCD to VCD
    Do you want to copy the VCD? You can just do a disk copy using any burning software.
    Or do you want to extract an mpeg from the VCD? You can do that with isobuster.
    Page 1 of 110 Goto page 1, 2, 3 ... 108, 109, 110 Next
    Jump to: Select a forum Video----------------Latest NewsNewbie / General discussions(S)VCD AuthoringDVD AuthoringDV and HDVDigital TVCapturingAudioNewbie ConversionAdvanced ConversionDVD to AVI, MP4, WMV, S/VCDDVD to DVDREditing, cutting and joiningSoftware PlayingLinuxMacMediaProgrammingRestorationSubtitle Portable VideoMedia Center PC Hardware----------------DVD WritersDVD RecordersDVD Players How To's----------------User guidesGlossary Other----------------ComputerOff topicFeedbackTestPollsShort Film Competition 2005 VCDEasy----------------VCDEasy General ffmpegX for MacOSX----------------ffmpegX general discussionffmpegX bugs and suggestions SVCD2DVD----------------SVCD2DVD General
    Powered by php_BB
    ( Forum Archive Forum Statistics)
    Rob
