I have a 6600GT and ever since I've gotten it the overlay video quality has been just awful. Everything looks like it's interlaced, but even when a video is paused the lines still flicker/crawl. I've tried every driver I could find.
I'm running it with a Samsung 213T LCD at 1600 x 1200 and the video looks the same in Zplayer and WMedia.
Any ideas what else I should try?
You may need to check the video overlay settings and also ensure your refresh rate is set to match your display.
Google is your Friend -
Well I don't see many overlay options in the driver. The 213T will only run at 60hz and that's what it is at.
Ok.... I don't know if this helps anyone but I disabled the divx and ffdshow drivers. DivX files still play and the quality is terrible, but it has fixed the shimmering problem. Should I try something besides ffdshow?
Also... I installed the nvidia purevideo drivers and my DVD playback is gorgeous now. -
The 213T will run at up to 80hz.Originally Posted by wotan
You're absolutely right -- never knew that before. I went from 60 -> 85hz in 5hz increments and it didn't fix the shimmering problem. Is there any other advantages/disadvantages at running at 80hz? I can't see a difference.Originally Posted by soundforbjt
.mov playback in video editors sucks
By RoundPorch in forum Newbie / General discussionsReplies: 6Last Post: 19th Oct 2011, 17:11 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38 -
DV capture quality sucks
By cooldude859 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 36Last Post: 28th May 2008, 16:07 -
Vista sucks
By Krispy Kritter in forum Off topicReplies: 1Last Post: 14th Jan 2008, 14:48
