Hi,
I want to make DVD movie from AVI file does DVD lab pro is able to do it or i reqire another software.
Regards,
Kern![]()
You need an mpeg encoder to create the dvd compliant mpeg-2 video files - e.g. tmpgenc, CCE basic, Procoder Xpress, HCenc etc, and an audio encoder that can create mp2 or AC3 output - e.g. ffmpeggui. You should also use a bitrate calculator to make sure you encode with a bitrate that allows your video to fit.
Another alternative is to use something like DivxtoDVD to create VOB files which can then be imported into DVD Lab Pro. If you do this, I suggest you allow DVD Lab Pro to demux when it prompts you.Read my blog here.
Plenty of guides on AVI to DVD to be read under CONVERT left.
/Mats
dvd lab pro movie numbers regularise
By sumeshkri in forum Newbie / General discussionsReplies: 1Last Post: 24th Oct 2010, 01:28 -
Making a comp. DVD with DVD-Lab Pro..
By Superstar24 in forum Authoring (DVD)Replies: 1Last Post: 26th Jul 2009, 18:24 -
DVD-Lab Pro 2, making shaped buttons from parts of menu background?
By bizzybody in forum Authoring (DVD)Replies: 0Last Post: 24th Dec 2008, 19:06 -
DVD Lab Pro - Question about movie merge
By shashidar in forum Authoring (DVD)Replies: 4Last Post: 17th Jan 2008, 15:41 -
DVD Lab Pro - Movie clips in menu
By flipzoso in forum Authoring (DVD)Replies: 1Last Post: 26th Oct 2007, 02:38
