I have burnt about 20 CDR's and 1 CDRW using the VCDEasy
program. My DVD player says it is compatible with VCD
see: http://www.vcdhelp.com/dvdlist/419.html
However, they wont work on my PC. Does the DVD player look in a specific location for the MPEG? I have downloaded and used just about EVERY program suggested. After 4 days of trying I am frustrated.
Here are a few of the programs I use:
1. From a DIVx file, I convert to MPEG by using....
2. VCD Easy.
3. I select the VCD template. All checks seem to go OK.
4. I burn the CD, no problems.
5. My DVD wont pick up the video.
Note: I can play it on my PC (WIN DVD) but, I have to select the MPEG track to get it to work.
It seems that my PC and DVD wont pick up the file it need to locate the MPEG.
Here is my system config:
1.8Ghz P4
512 Ram
(3) 80 Gig Hard Drive
Firewire and USB Support
DVD Drive
CD R/RW Drive
Please help. I am trying to put home movies of my pregnant wife on to a disc to play on the DVD when family comes over. I am pretty computer literate, but I am stuck.
Here is the format that VCDEasy give for the final product.
CD:/ TITLE HERE
--CDDA
--CDI
===CDI_IMAGE.RTF
===CDI_TEXT.FNT
===CDI_VCD.APP
===CDI_VCG.CFG
--EXT
--MPEGAV
===MYMOVIE.DAT
--SEGMENT
--VCD
===ENTRIES.VCD
===INFO.VCD
Then, there is no more.
Do I need an XML filE?
Do I use a BIN/CUE file?
When I load an MPEG and Analyze it.. this is what I get. I am not sure how to interpret it.
MPEG2, PlayingTime=62.262s, Bitrate=2334800bps, PtsOffset=0726s, 7724 packets
Video Stream: Motion Video, 480x480, 29.97003fps (NTSC), 2048kbps
Audio Stream: Audio Standard MPEG layer2 Stereo, 44100Hz, 229376bps
mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:08.2d]
mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:00.4a]
mpeg user scan data: one or more BCD fields out of range for 'previous_I_offset': [00:00.4a]
mpeg user scan data: one or more BCD fields out of range for 'backward_I_offset': [00:08.2d]
mpeg user scan data: from now on, scan information data errors will not be reported anymore
I hope someone can help me.
Dave Steele
www.steeleimaging.com -
It`s not a standard VCD file.
VCD=mpeg1 - video=1150kbps - audio=224kbps
Pal=352*288 25fps
Ntsc=352*240 29.97fps
OH
the file you have is an svcd, your dvd player just doesn't support it
"The software said Win XP or better, so I Installed Linux" -
Congratulations! I would guess that by now your wife has delivered (note the date).
If you still would like to use the material without re-encoding, here's what I would do...
1. Get the latest version of VCDGear
2. Using VCDGear, do a DAT -->MPEG conversion to make an MPG file on your hard drive that you can work with.
3. Author an SVCD using VCDEasy (get the latest version). Make sure you have "Compliance Checks" ON. Burning this will give you a standards-compliant SVCD, which may be playable on your player. I couldn't tell from the link you gave, so check again to see if it's SVCD compatible.
4. Get a copy of PowerDVD or WinDVD (recent). It should then be playable on your PC in Disc Mode.
5. If you REALLY want it to play on your set-top and it isn't SVCD compatible, get DVD2AVI and TMPGEnc and actually do a Re-encode (MPEG2 -->MPEG1) and author w/ VCDEasy to make a compliant VCD.
As always, check this site (on the left <--) for Player compats/HowTo's/(S)VCD Disc structures, since it is just about the last word on the subjects.
Good luck from a father of 4,
Layout of mediainfo
By pooksahib in forum Newbie / General discussionsReplies: 4Last Post: 27th Feb 2012, 10:30 -
DVD with .layout and .LAY files
By Case in forum MacReplies: 1Last Post: 9th Sep 2010, 04:00 -
I require assistance with a layout, please.
By Zynn in forum Authoring (DVD)Replies: 3Last Post: 5th Feb 2008, 09:39 -
Encore Layout Help- Im getting embarresed
By RealitySets in forum Authoring (DVD)Replies: 1Last Post: 12th Sep 2007, 03:12 -
Got a DVD plays correct, copies correct but refuses to write on a blank DVD
By cemman in forum Authoring (DVD)Replies: 16Last Post: 21st Jul 2007, 16:09
