Here's another HC guide.
http://www.doom9.org/mpg/hc.htm
The main difference between it and you is that you're using an AVI for a source. So, after installing AviSynth, you open the AVI in FitCD and use the script it gives you. You create a text file, but rename the extension to .avs. Maybe name it "Movie.avs". Inside will be the script FitCD gives you. You follow FulciLives' guide to FitCD farther up the page.
By the way, make sure you add this as your last line:
ConvertToYV12()
if you're using HC.
Test the script in VDub(Mod) before trying to open it in HC. Open the script in VDub(Mod) just as you would an AVI. If there's an error, post both the script and the error message here. Scroll around and see if it looks OK. Then open it in the HC encoder and take it from there.
any suggestions pls?
Maybe switch your hobby from video encoding to stamp collecting?![]()
Results 31 to 34 of 34
Thanks FulciLives, I have tried your guide and it walked me right through, This helps me to understand a bit more about working with encoders using avs files, Guns1 has given me a lot of help on this subject, And I am thankful to the both of you for sharing your skill
, FitCd and its scripts help me to see and learn, the more simple scripts, and how they look. Now for a little more practice......
DVDLab Pro 2 Aspect Ratio Woes
By Super Leviathan in forum Authoring (DVD)Replies: 12Last Post: 20th Dec 2011, 15:15 -
Need help with aspect ratio woes after rendering/converting
By mpalm887 in forum Video ConversionReplies: 8Last Post: 26th Jan 2010, 03:45 -
Resolution vs Aspect Ratio
By triptych in forum Newbie / General discussionsReplies: 17Last Post: 7th Aug 2009, 08:23 -
DVD to Ipod resolution & aspect ratio
By lemmy999 in forum Portable VideoReplies: 1Last Post: 18th Jul 2007, 14:47 -
Xvid to DVD with aspect ratio intact?
By StratPlaya in forum Video ConversionReplies: 12Last Post: 5th Jul 2007, 14:02
