How do you remove a 30-story building in the middle of a city? Very carefully.
http://wmp.mainichi-msn.co.jp/MSN/2006/03/20/building.wmv
Results 1 to 12 of 12
Originally Posted by BJ_M
You can run a plane into the side and it will come down perfectly straight.snappy phrase
I don't know what you're talking about. -
I saw that no the news the other day, they said something about they charged people to watch it come down, must have been to be up close or something because i'm sure they clear out buildings near by ect. for safety reasons.....
do they ever go wrong?
I can't imagine what would have happened if it had toppled to the side as there were buildinsgs around it also -
yea -- one went wrong about a month ago - i think in Nebraska ..
it didnt fall completely .. and what did fall went the wrong way ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
They do that here in Vegas all the time. They just shut down a section for a period of time. To be close you paya charge, but it's primarily for the use of hardhat, dust coat, ventilation mask, goggles, & liability clause.
They purposefully make some of them lean to a small angle, though I'm not sure why, but it may have something to do with causing certain supports to collapse properly. The building naturally wants to collapse flat. The demolition crew usually wants it to collapse inward on itself or in a direction to make sure the supports collapse completely. You may blow a support and it just drops down 10 feet still standing. I wouldn't want to try and get anywhere near it if it got stuck standing like that.
See, the building wanted to collapse back towards it's flat center and stood up. poor job. It started leaning properly though. The base blow outs probably didn't ignite properly.
yea --- and now what to do ?
Wish flip4mac would hurry up and make a Universal Binary version so I can actually VIEW that.
They wait 2 days, send in a crew of 4 people to check structure, clear a much larger area COMPLETELY, place remote charges near where it looks like the strongest support seems to be.Originally Posted by BJ_M
That or call the military for help. :/
yea that would work !
Does the SpursEngine devices, IE Leadtek's WinFast PxVC1100 work good?
By TBoneit in forum Video ConversionReplies: 3Last Post: 15th Aug 2009, 16:50 -
Looking for good DVD recorder to work with HF200
By kritayot in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 20th Jul 2009, 17:55 -
What's a good script to work with my video?
By rocky12 in forum Newbie / General discussionsReplies: 6Last Post: 27th Apr 2009, 20:23 -
Got a very good used sony F717 camera from work but it has a display error
By MidnightMike in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 10th Mar 2009, 08:26 -
Anybody good at making title animation want some paid work?
By Mutt_CA in forum EditingReplies: 1Last Post: 16th Feb 2009, 22:29
