  1. How can I prevent poor quality audio on some of the conversions (AVI>DVD) I
    do. It seem some of my full-length features seem to periodically "hum"
    thoughout the showing. I'm not sure if it's the original file, or my software and/or hardware.
    (I can give file stats if need be).
    Thanks in advance.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    sounds like cams from a theatre - where the audio is captured from the hearing impaired system --- which i understand causes a hum
    easy solution to this -- dont download cams or ts files
  3. The point is that the AVI audio is ok, I suspect something with either a software setting, the software itself, or possibly my PC. Just wondering if someone had some first hand experience.
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    what are you using to convert ?
