Hello Everybody!
Ik have a problem with aspect ratio in Adobe Encore DVD 2.0. My files are 16:9, but encore dvd plays them as 4:3 files, and so the image will be transformed. In the 'properties' tab, I see a radio box where I can choose wheter I want to play the files as 4:3, or as 16:9, but this function is disabled..
Can anyone help me?
Greetings
Jens
go to greferences, and look for the preview aspect and change it to 16:9.
This issue wont affect your project, this is just a preview issue. Adobe wont reencode or crop your file, it will respect your aspect ratio. The only aspect ratio you should worry about is the one for your menus. that one you DO can change it from 4:3 (default) to 16:9 if you want to.
Try to create the DVD just like you have it right now (create a folder DVD so you dont get a coaster, or preferably use a rewritable media) and play it. You will notice Encore DVD in fact, respected your asset's original aspect ratio when the DVD is built.
Adobe Encore DVD Question...
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 26th Aug 2011, 06:46 -
Adobe Encore DVD and subtitles ...
By Liru in forum Authoring (DVD)Replies: 17Last Post: 14th Oct 2010, 17:05 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
Problem in Adobe Encore DVD
By zombie_chan in forum Authoring (DVD)Replies: 10Last Post: 24th Apr 2008, 01:09 -
Adobe Encore 2.0 DVD Menu
By ozab in forum Authoring (DVD)Replies: 0Last Post: 13th Aug 2007, 17:03
