  1. Member erik1958's Avatar
    Dec 2005
    Netherlands
    I am trying to write a DVB-T TS decoder.
    The PAT parses OK.
    The PMT shows some weird things.
    The least 8 bits of the PID's of the ES's are OK but the upper 4 bits do seem to change per PMT I parse.
    So
    once I see (PID in hex)
    PMT with pid = 20
    PCR pid = 1022
    ES[ 0] type = 2, ES[ 0] pid = 1022
    ES[ 1] type = 4, ES[ 1] pid = 1023
    and then I see
    PMT with pid = 20
    PCR pid = 1a32
    ES[ 0] type = 2, ES[ 0] pid = 1a32
    ES[ 1] type = 4, ES[ 1] pid = 1a33
    And then I see (what it should be)
    PMT with pid = 20
    PCR pid = 1522
    ES[ 0] type = 2, ES[ 0] pid = 1522
    ES[ 1] type = 4, ES[ 1] pid = 1523
    ES[ 2] type = 129, ES[ 2] pid = 1530
    They all have the current bit set so its not the "next" PMT
    Any clues?
  2. Anonymous
    Guest
    It is legal to specify multiple programs on one PMT PID. Many PAT/PMT parsers do not support that. DGIndex doesn't too, but at least it's on my to-do list.
  3. Anonymous
    Guest
    I have rewritten the PAT/PMT parser in DGIndex to correctly handle this kind of situation. If anyone needs the source code before I make a release, feel free to PM me for it.
