    Feb 2006
    Malaysia
    I do not own any Divx capable player at the moment so would like to check with your guys how the subtitle (.srt or .idx/sub) shown in the movie when played in standalone player.
    1. Would the subtitle shown sometime be too small/big ?
    2. Is the standalone player has the feature to adjust the size when it is shown too small or too big ?
    3. how would I know if my subtitle size has the best fit for the movie when it plays ?
    Just want to find out before I backup all my movies (with the subtitle file) into CD/DVD permenantly.
    thanks.
    Dec 2004
    Australia
    1. VobSubs are bitmap based, so it depends on the subs. For text based subs, that depends on the font in the firmware.
    2. Possibly on the more expensive players like the Z500.
    3. For text. You don't.
    Feb 2006
    Malaysia
    thanks for reply.
    for what you have said, could I jump to the conclusion all these depends on standalone player ?
  4. Member ricardouk's Avatar
    Mar 2005
    Portugal
    you can check the final size of the subs if you use "avisub" or "srt2bmp" to mux your srt/idx subs onto avi/divx file
    guides:
    avisub:
    http://www.trustfm.net/divx/SoftwareAviSub.html
    srt2bmp:
    http://projects.gdion.biz/guides/dmfwithxsub.html
    I love it when a plan comes together!
    Feb 2006
    Malaysia
    thanks you guys for the info. I believe I have got what I wanted.
    cheers!
