I tried to burn a couple of mpg videos to a VCD using Nero Express. I realize this is not the predominant software, but it is "newbie" friendly. Anyhow, while performing this operation, I got the following message " The mpg video is not VCD compliant, it will be converted during the burn process". About halfway into the encoding process, I got a mesaage that an encoding error had occured and the operation had been aborted. I tried two other discs and got the same message. Anyone got any ideas what is happening? Thanks in advance.
Originally Posted by showtime586
What are the specifications of the mpg you're trying to create a VCD out of, with respect to resolution and bitrate? (If you don't know, use GSpot (latest beta, 2.52 IIRC))
How did you create this mpg?
mpg video for VCD must be mpeg1, 352x240/288 (NTSC/PAL) CBR (max) 1150 kbps
Generally, use VCDEasy to author VCD. That's a newbie friendly app, because it works.
/Mats
XviD4PSP Re-Encoding Error?
By Kid Boruto in forum Video ConversionReplies: 1Last Post: 26th Apr 2011, 03:07 -
encoding error...
By rkane in forum ffmpegX general discussionReplies: 6Last Post: 2nd Oct 2010, 00:45 -
Error when encoding
By edgarfrito in forum ffmpegX general discussionReplies: 1Last Post: 1st Sep 2010, 23:55 -
Keep Getting an Error when Encoding
By kee2987 in forum ffmpegX general discussionReplies: 2Last Post: 16th Mar 2010, 11:45 -
error while encoding, someone explain
By arabian in forum SubtitleReplies: 3Last Post: 19th Jan 2008, 07:42
