    Dec 2001
    jamescichocki
    I have a vcd movie that has a phone number on it and I believe it was burnt using Nero, I want to remove this phone number and I use Nero as well. I believe that I found the file on the vcd which is a Microsoft Word file but can't open it using Microsoft Word.I can use drag and drop in Nero but when I do that I somehow exceed the capacity of the cdrom,yet if I do a cd copy I can fit everything on the cd rom with no problem. How do I drag and drop and still stay within the capacity of the cdrom? Why does drag and drop show so much more on the cdrom? What am I doing wrong?? Thanks! In advance.
  2. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    Just copy the movie part to your harddrive. Open NERO and extend the maximum filesize with the nERO options. Then insert an empty CD in your drive, and create a VCD with NERO. should give you no probems
    The Dutchman
