The following is a cross post from the CDFreaks where I was not getting any replies.....
Now that CDSpeed 4.5 now shows:
* Added seperate Create Disc function with following improvements
- buffer level display, both graphically and numerically
- CPU usage display, both graphically and numerically
The question is (since this seems to effect both of my DVD Writers {NEC and a HP/LG drive}):
Why is it that when I create a 'data DVD disc' I get a really nice stair step burn up to 16X
The data disc's CPU cycles stays a steady 3% while the .ISO burn the CPU cycles jump between 1% and 39%???
Also when I try to burn an .ISO the buffer is jumping all over the place at about the .5gb point in the burn and the burn starts having varying speeds from a low of 2.5X but never tops 10X.
I have turned off all visible background programs, defragged the harddrives and even unplugged the computer from the network just to make sure...
Something is telling me that there must be some sort of setting in WindowsXP for harddrive or CD-Rom buffering that I must have set wrong but I don't have any ideas (or remember) what I or some speed tweek setting that changed and really slowed down my harddrive access and no idea as to where to start looking . ... . HELP!![]()
You may have already taken these steps - If so please ignore:
1. Verify that no drives - burners or hard drives - are running in PIO mode.
2. If everything is in DMA mode - Run a burst rate test on both burners to insure > 22-23 MBs
What media are you testing with? What specific drive models are you using? -
Are DVD writers on IDE channels separate from HDD? HDDs should be on one channel and other drives should be on another channel.
The Harddrives are both: [both are less than a year old]
Seagate: ST3160023A
IDE Channel "1"
The DVD drives:
Master: HP 740i/b w/ HJ24 firmware
Slave: NEC 3540 w/1.04 Liggy firmware
It does not seem to mater as to which media I am using as I have tested with (all DVD+R)
Maxell 002 / 003 /004,
Verbatium 16X, 16X Printable, 8X Lightscribe MCC 03/04 based media,
HP 8X Lightscribe CMC MAG E01 based media.
TDK 8X printable CMC MAG E01 based
--David -
Originally Posted by DavidEC
Do this for both burners. -
HD Tune: ST3160023A Benchmark _C_
Transfer Rate Minimum : 17.0 MB/sec
Transfer Rate Maximum : 41.1 MB/sec
Transfer Rate Average : 36.5 MB/sec
Access Time : 15.1 ms
Burst Rate : 44.6 MB/sec
CPU Usage : 4.8%
HD Tune: ST3160023A Benchmark _D_
Transfer Rate Minimum : 29.0 MB/sec
Transfer Rate Maximum : 42.3 MB/sec
Transfer Rate Average : 39.8 MB/sec
Access Time : 15.0 ms
Burst Rate : 44.5 MB/sec
CPU Usage : 5.7% -
Troubles burning avi to a dvd with nero vision
By falcon1 in forum Authoring (DVD)Replies: 3Last Post: 13th Oct 2008, 11:36 -
Hard drive speed problems
By toby223 in forum Capturing and VCRReplies: 3Last Post: 17th Jul 2008, 05:50 -
Troubles burning OTA HD to DVD
By mattman1968 in forum DVB / IPTVReplies: 3Last Post: 3rd Jun 2008, 07:41 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 02:41 -
burning troubles on the back end
By beck59 in forum Authoring (DVD)Replies: 1Last Post: 24th Dec 2007, 23:11
