    Apr 2005
    Canada
    I have a dvd which has poor audio/video sync. It is really bad. I don't know why. Is it possible that in ripping and backing it up I may end up with better audio/video sync just from the rip/backup process? Or is there something I can do to force the audio/video to be fixed in the backup?
    thanx,
    Apr 2004
    Miskatonic U
    No, and, er, no.
    You can rip it, demux it, and adjust the audio to try to fix it. Is the audio out the whole way through, by about the same amount ? Of does it drift out over time ?
    If it is out by a constant amount, then you just need to fix the dely and remux the audio.
    Read my blog here.
    Apr 2005
    Canada
    It is semi-similar. To be honest, its another dvd in the same condition as the last one I had which did this. Its in poor scratched up condition. Probably something that should have been backed up previously. I generally take good care of my dvd's, but when you buy used, you sometimes get less than perfect. I could always take it back to have them buff it or whatever. I'll see how the backup process goes.
