I was wondering how I should label rewritable discs. A sharpie is permanent and I have heard that sticky labels ruin your disc. I have a little brother label maker, but didn't know if the label would come off when I burned something different or if it would ruin the disc as well. Any ideas would be appreciated.
Thanks,
John
Results 1 to 12 of 12
I use a Sharpie to place a code on it like RW-0603g (bought 0603 #g). Then I use an Excel spreadsheet to maintain a list of what is on the DVD-RW.
What edDV said, and you can mostly wash off the Sharpie ink with 99% isopropyl alcohol and a paper towel if needed to re-label it.
I use whiteboard/dry erase markers.
"Art is making something out of nothing and selling it." - Frank Zappa -
I would think dry erase would come off way too easily, and to make it worse, inside your drive/player.
TANSTAAFL -
I think EPSON makes a regular inkjet printer that have an adapter to print on CD/DVD. I was waiting for my HP inkjet printer to die, so I can look into one. I am still waiting..
I use wet-wipe water soluable pens that are made for writing on
acetate rolls on overhead projectors.
They don't bead up, come in many colors...and are easy to erase when I re-record
on the disk. -
I use a Sharpie and remove the ink with CD cleaning fluid when I erase the disk
I change the volume label of the actual disc.
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Sony DVD/CD Rewritable Drive Unit Model# DW-U18A
By j80r50m in forum ComputerReplies: 1Last Post: 26th Apr 2010, 23:06 -
Disc name/label being cut short in Nero.
By richard_m_morales in forum Authoring (DVD)Replies: 5Last Post: 25th Sep 2008, 13:20 -
Players that support multisession rewritable disks?
By rvman in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th Mar 2008, 10:30 -
DV+Rewritable
By knowmyname_20 in forum Newbie / General discussionsReplies: 1Last Post: 25th Sep 2007, 10:58 -
Rewritable DL ???
By fredfillis in forum MediaReplies: 13Last Post: 30th May 2007, 20:49
