I've been trying to find the best settings for converting DVD's to a format that I can stream to my freshly modded Xbox and have been having a hell of a time getting it right. I finally got settings that work for AC3 passthrough using mencoder MPEG4 for video and "passthrough" for audio. No other settings worked - all I ended up with was stereo instead of 5.1.
Anyway, back on point. Now I can't seem to get the aspect ratio right to be able to watch both on my 16x9 tv AND my Mac. The DVD I am using is 2.40:1 ratio. ffmpegX auto selects 16x9 for size, but that still leaves bars. If I use Autocrop, forget about it! I end up with a rectangle in the middle of the screen with only a section of the video actually showing! If I set the crop myself to what I think it should be (and incidently, Handbrake uses these settings) - 64 - 64 - 0 - 0 - than it will stretch fine on the TV, but is all compressed on my Mac. I've even tried "Unconstrained" and setting the crop - I get the same thing. In fact I've tried just about every combination I can find and get the same thing.
So, is there a way to preserve the AC3 5.1 audio as I have done AND get the video cropped the way it should be, too? Please? Help?
Thanks.
Anthony
aspect ratio
By devdev in forum Video ConversionReplies: 5Last Post: 19th Apr 2012, 18:31 -
Aspect Ratio
By ping182nz7 in forum EditingReplies: 12Last Post: 26th Apr 2010, 14:30 -
Aspect Ratio
By jackowens in forum Video ConversionReplies: 2Last Post: 18th Mar 2009, 18:40 -
16:10 Aspect Ratio
By SWBisbee in forum Newbie / General discussionsReplies: 4Last Post: 31st May 2008, 02:41 -
what is aspect ratio?
By mai_hnf in forum Authoring (VCD/SVCD)Replies: 3Last Post: 29th Sep 2007, 23:29
