How do I take a dvdfabdecrypted dvd which is larger than one DVD +R/W and fit it onto two discs?
I have ANYDVD and DVDFabDecryptor (anydvd trial). I am using an Ashampoo trial for now. I may get Nero 6.6 since Shrink can use that. Will shrink allow me to spread the dvd across two dvd +r or +rw? I will check. BTW... I read the sticky (from 2003!) and dvdxcopy is no longer available.
thanx in advance for any input
Have you checked the wonderful guides on this site? Look left under the "How To" section and either perform a search or check the DVD Backup section. You will find lots of info there, believe me.
Cheers!
TTWC"I've got a present for ya!" - TTWC -
I have been checking them. I will keep checking. Sometimes things change as software changes so people have new advice from recent experience.
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 17:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 12:34 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 08:59
