  1. i normally convert my avi to vcd / svcd / dvd using tmpgenc and i'm quite happy/satisfied with it
    now i'm looking for a software that will convert mpeg1/2 into video_ts w/o any quality loss (if possible) so that i can use dvdrebuilder to finally encode it and fit it to dvd5
    i do this cause i normally try to fit more than 1 movie in a dvd5
    any suggestion (comment?)
    tda! or click on Tools and Authoring(DVD) in the menu here to the left.
    and it is better to convert to correct size direct instead of using dvdrebuilder, use the wizard in tmpgenc or calculate the output size manually using a bitrate calculator.
