i have two video files with different audio rates and ive been trying to join them using virtual dub,is there a way i can correct the audio sampling rate by matching them?
Extract the audio with a program such as GoldWave, change it to the settings that you want, then remux it.
I believe you can also use virtual dub to change to the audio. Open the file, set video to direct stream copy, change the audio to settings to what you want, then save the file.Google is your Friend
Audio Sampling Rate Info Wrong - DV-AVI Capture
By newtotheworld in forum Capturing and VCRReplies: 3Last Post: 21st Nov 2011, 22:18 -
The audio streams have different sampling rates, blah blah
By Kobong in forum EditingReplies: 5Last Post: 8th Jul 2008, 06:07 -
Issues with sampling/audio sampling/data rates and VdubMod
By Suprman37 in forum Video ConversionReplies: 4Last Post: 22nd Feb 2008, 01:09 -
Simplest way to join AVI files with diffferent Sampling rates.
By dagerousdave in forum Newbie / General discussionsReplies: 6Last Post: 15th Nov 2007, 07:03 -
how to rip audio from DVD and AVI without re-sampling
By ted demen in forum AudioReplies: 9Last Post: 23rd May 2007, 10:23
