WinXP seems to keep track of every installation of itself even if the installations were done on different drives no longer inside the computer! On the startup screen, it asks which OS to run (2 versions of XP). One version no longer even exists. So how do I remove that one version of XP from the startup screen so it will automatically load the other without asking which one?
there should be a file on the root of your c: drive called "boot.ini"
just copy and paste this in there.
Code:[boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
I think that your interpretation is not entirely correct. Can you say a bit more about your "dual" XP config? Are you talking about boot menu only or second (residual) installation you suspect?
If it's about boot only (may be due to incomplete setup) you can edit/remove the 2nd option from Boot.ini (root on boot drive) so it looks like below.
Example:
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOW S
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Professional" /fastdetect
Go to Start menu then click Run, enter: msconfig.exe.
Click Booti.ini TAB and then "Check All Boot Paths" Windows should correct this error for you automatically.
To edit boot.ini right click My Computer, Properties, Advanced, Startup and Recovery Settings, Edit. -
Well, that was easy. Wish all computer problems could be fixed so simply.
Installation of ffmpegx
By Docdawh? in forum ffmpegX general discussionReplies: 12Last Post: 19th Nov 2010, 01:13 -
Easycap 2.0 Installation.
By xAnonymousx in forum Capturing and VCRReplies: 2Last Post: 7th Jun 2010, 08:37 -
Solid State HD for WinXP Pro / Vista boot installation….
By retroborg in forum ComputerReplies: 2Last Post: 12th Oct 2008, 15:09 -
Best/Ideal HD partitioning for a new WinXP Pro installation
By retroborg in forum ComputerReplies: 4Last Post: 12th Oct 2008, 09:45 -
FixVTS installation
By Gerald Sr. in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2008, 17:10
