If I convert a 400 megs avi file into mpeg will it be able to fit on a 1 cd (vcd) and how long will the conversion take ?
It's very easy to calculate the size of a vcd...a vcd is about 10 MB /minute. And a VCD fits 74 min/video=740 MB...if it's above that you need to cut it.
To just join/cut video should just take some few minutes. To encode/convert a avi to mpg takes some hours depending on your processor.
Thanks for the replies Baldrick, ur one real helper
but i have two more question... when burning it on a 74 min cd, does it use the minutes on the cd or does it use the amount of space on the blank cd ? and how long will it take to burn 400 meg file on a pentium 2 - 350 proccesor
<font size=-1>[ This Message was edited by: w4zzabi on 2001-07-18 11:02:11 ]</font>
<font size=-1>[ This Message was edited by: w4zzabi on 2001-07-18 11:04:20 ]</font>
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 08:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 13:13 -
Newbie needs help!!!!!! DVD to xbox 360 streaming
By JohnS719 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2010, 08:38 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 09:43 -
Newbie looking for ideas..
By HaleC. in forum Newbie / General discussionsReplies: 8Last Post: 10th Jul 2008, 13:37
