When authoring a DVD is it possible to put 4.7 GB worth of Data or only 4.3 GB?
4.37GB.
https://www.videohelp.com/dvd.htm#1000
DVD-5, holds around 4 700 000 000 bytes and that is 4.37 computer GB where 1 kbyte is 1024 bytes* . DVD+R/DVD+RW and DVD-R/DVD-RW supports this format. Also called Single Sided Single Layered. This is the most common DVD Media, often called 4.7 GB Media.
* In the computer world is 1 KB data = 1024 bytes so 4 700 000 000 bytes / 1024 = 4 589 843KB / 1024 = 4482MB / 1024 = 4.37GB. See section 3.3 in the DVDDemystified FAQ here.
DVD+R/DVD+RW/DVD+R DL and DVD-R/DVD-RW exact sizes
DVD-R/DVD-RW = 4 706 074 624 bytes ( 4488 MB )
DVD+R/DVD+RW = 4 700 372 992 bytes ( 4482 MB )If in doubt, Google it. -
Yes, about 4.37 real gigabytes.
Which is about 4.7 "weasel" or "marketing" gigabytes.
Regards.Michael Tam
w: Morsels of Evidence -
The same applies to other storage mediums, including floppy disks, USB memory sticks, and even Hard Disk Drives. Shocking isn't it; to see your 250GB Hard Drive only showing 232GB.
For some reason, CDs show their true capacity. A 700MB CD is actually 700MB.
Longevity of Standard DVDs and BluRay DVDs
By bmccollum in forum MediaReplies: 10Last Post: 20th Oct 2010, 19:32 -
2.0 to 5.1 for dvds?
By blacksheepdownunder in forum AudioReplies: 6Last Post: 30th Dec 2009, 11:33 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 17:03 -
Ok, best tool for converting dual layer dvds to single layer dvds is?
By burgkev in forum Authoring (DVD)Replies: 5Last Post: 25th Aug 2008, 02:02 -
I want software that copies DVDs and transfers torrents to playable DVDs!
By maccaneer in forum MacReplies: 14Last Post: 28th May 2007, 10:02
