i was turning my avi to mpg and i had 10 seconds left of the movie to go and an error came up. i went to the mpg file and it showed it was 761 mb but it only places 2 seconds i need help.
Hi,
Experience has shown me that there maybe an error within your source file.
Launch TMPGEnc and load the .AVI as the source Video and Audio file, click Settings/Advanced/Source Range and move the little slider to the right very slowly and when you get to the END, press the little LEFT arrow and you may beable to reproduce the error.
You may have a couple of options:
1. Find a program called DivFix.exe from http://www.vcdhelp.com/faq.htm#fixdivx and strip the .AVI index, then Rebuild Index, or maybe
2. If you find an error by moving the slider, you can pick the spot a split second to the right of the error and ENCODE the remaining part of the file, then rejoin with the 1st part.
Hope this helps!!!!!
Read error with TMPGEnc
By MasterScreech in forum Authoring (VCD/SVCD)Replies: 2Last Post: 24th Jun 2010, 20:08 -
Bizarre error using TMPGEnc 4.0 Xpress?
By the colonel in forum Video ConversionReplies: 1Last Post: 29th May 2010, 21:30 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 22:44 -
TMPGEnc 3 error 0.80070005
By impmon2 in forum Video ConversionReplies: 6Last Post: 18th Jul 2008, 22:00 -
TMPGEnc Plus Error!
By redtrigger in forum Video ConversionReplies: 15Last Post: 9th Jul 2007, 12:05
